| Kenwood Forum For discussion of land mobile radio products manufactured by Kenwood. This is to include the TK(R) and NX(R) series radios and their associated accessories. This forum is not for the TM series; use Amateur Radio Equipment. |
05-08-2011, 5:08 PM
Kenwood TK-2180 / NX-700 Firmware Programming
My agency has sent us the software to update the FIRMWARE, but have provided no instructions to assist us. Can anyone here tell me how in the world to update the radio with the new version?
Thanks in advance!
05-08-2011, 11:28 PM
Fw
Do you just have the software or do you have the firmware file too? If you have both and the programming cable, then what you will need to do is open up the f-pro program. It should be in the root file of the KPG software in the program files folder.
1. Browse for and open firmware file in F Pro
2. Check Com Port settings and connect radio
3. put radio in programming mode by holding down "S" while turning on
4. Select the baud rate on the radio by pressing the bottom side button ( i normally use 57600)
5.match the baud rate in the drop down menu in f pro
6.write to radio.
The button squences are for the 2180, im not sure what they are for the NX series. also this is all from memory so if i missed a step someone please jump in and correct me. Oh and every time you do something with your radio BACK UP YOUR DATA FILE
Hope this helps!
Conner
01-29-2013, 9:24 PM
6.write to radio.
Hope this helps!
Conner
My radio nx700 runs with the firmwere 2.32 now. I'm trying to reprogram with new firmware 3.0 but I can not.
Because I can not set the radio in program mode after turn power on with nemu button depressed.
I started Fpro, set the COM port, baud 115200. Then turn power on the radio with the Menu botton depressed but I don't see the "PROGRAM 115200" displays on LCD.
The radio can read/write normally with KPG-111D software.
Thanks for helps.
02-07-2013, 8:51 AM
in the KPG-(whatever it is) in the first optional feature box there should be a Firmware programming check box. make sure it is enabled, write to the radio, then try the firmware button combo.
02-07-2013, 10:46 AM
I know that I am going to regreat this, but I need to jump in anyway.
viet5d with the lack of knowalge that you have admited to and shown, why are you trying to do some thing as advanced as a firmware upgarde, that you do not even need to do?
Leave the radio along until you have a better under satanding of radio's and how they work.
rtm8575 I have to also ask you, why does your department think you need to upgrade the firmware?
Where your radios acting up to the point that maybe doing a firmware change would help correct the problem?
For the most part, if a radio is working correctly, then a firmware upgrade is not needed even if the manufacture releases a new version.
Check the changes in the newer version, and if it is just a simple addon and you really do not need it, then for the most part you do not need the up grade.
Upgradeing firmware for the sake of upgrading is usally more trouble then it is worth.
It is like currently driving a 2009 x car modle y and now there is a z mod that does not do anything major, but every one wants it.
If a radio is working, leave it alone.
02-07-2013, 11:51 AM
Location: Bringing you happy thoughts and crunching the numbers daily since 2012
^ ^ ^ This
02-07-2013, 8:00 PM
Thanks very much !
Now, I know how to update the firmware.
I'm thinking Why I have to leave my radio alone when I can do something better ?
02-10-2013, 6:36 AM
MDC-1200 Is, IMHO, a major feature to have included in a firmware upgrade, especially from Kenwood. If Viet5d drops $200-$800 on a radio, he has the right to modify or alter it (legally, of course) however he wants to via firmware or whatever. If you don't have anything useful to say to help the OP, I'd recommend saving the condescending, rude comments. You didn't "need to jump in anyway" you shared nothing useful, and took up space with a useless post.
Viet5d Im glad i could help you out man
02-12-2013, 4:58 AM
Originally Posted by viet5d
Thanks very much !
The new 010G firmware on my M4512GBSSD1 is giving me those dreadful beachballs every now and than(about 10 times a day) for no reason. The beachballs disappear after about 40 seconds. With firmware 000F I had no problems(no beachballs) what so ever. I still have the 000F firmware with me on a CD. Would it be safe to boot with it and downgrade? Will it work? I also have the 0309 firmware on CD. Will it be even better to bet on the 0309? I have the late 2011 iMac with Mountain Lion 10.8.2. Can you hekp me please... THANKS!
