Go Back   The RadioReference.com Forums > Commercial, Professional Radio and Personal Radio > Kenwood Forum
Kenwood Forum - For discussion of land mobile radio products manufactured by Kenwood. This is to include the TK(R) and NX(R) series radios and their associated accessories. This forum is not for the TM series; use Amateur Radio Equipment.
Old 07-08-2011, 8:29 PM
Default General programming info on TK-7180
I'm thinking of geting a used TK-7180 on that big auction site, to use as a home 2 meter station and to monitor the public safety frequencies relevant to me (I'm a volunteer EMT and Red Cross disaster volunteer). I would of course get the programming cable and software.
Q1. Is the software easy to use, or do you have to apprentice to someone in the trade to figure it out?
Q2. The radio is described as having zones and groupids/ channels. I suppose a zone would be a geographic area where a certain bunch of channels could all be heard at the same time. So if later I used it as a mobile, I might set one for the northeast part of the state, one for the northwest part of the state, etc., right?
I suppose that groupids would only be used in trunked radios (none of those around me) and channels would be used in conventional systems. So each channel would be for a particular agency or purpose in a certain zone (county sheriff, city EMS, city dog catcher, etc.) Have I got that right?
Old 07-08-2011, 9:11 PM
b7spectra's Avatar
EMS Dispatcher
Kenwood software is probably one of the most user friendly I have ever used (especially after using MTX DOS based for TRS)!
You will need a cable (easily available on eBay) and the software (the internet is your friend).
Zones & Groups are just like on scanners. Now if you are talking TGID's (TalkGroup ID's), it is a horse of a different color. With that, you will need a radio shop (most likely the agency) do the programming as they have all the codes that will make it work. And if it is an TRS, you will need a user ID.
If you want to just be able to monitor a system, get a scanner. Cheaper and safer.
\/\|k.e
EMS Dispatcher/Advanced EMD Certified
EMT/Paramedic, retired
Old 07-08-2011, 9:15 PM
Of course, I want to talk on the ham frequencies. Also, I may want to talk on the public safety frequencies very briefly, just to let my fellow volunteers I'm responding. The handitalky they issued me often isn't heard until I get to the flatter parts of town.
Old 07-08-2011, 11:00 PM
ramal121's Avatar
The TK-7180 is a very nice radio and should suit your purpose well. It can be used on LTR conventional trunked systems but it sounds like you would not need to use LTR.
By default, the programming is for conventional channels and you will use this. It has a maximum of 512 channels and 128 zones. You can set this up anyway you want. You could have 1 zone of 512 channels, 128 zones of 4 channels or any combination in between. I set my zones by service ( fire, PD, ham, customers etc). For scan, you could add or delete channels or turn on/off entire zones with a push of a button.
The software is easy to use, however, the radio has many features and you will find menus and tabs that will leave your head spinning. The use of the help files will explain things. There is also a programming manual for this model. Basically, if you can set up your zones/channels, program the buttons the way you want them, set scan parameters to your preference, you will be set to go. Then you could go back at a later date and figure out the rest of the program and change what you want, forget the rest.
Old 07-09-2011, 11:04 AM
burner50's Avatar
The Third Variable
It can be set up any number of ways.
I have a zone for the "Old" channel plan at work from the old 16 channel days, One that has all 200 channels, one for ham, one for weather, one for scanning the local pd/fd
RadioReference.com Forums Moderator
burner50@radioreference.com
Old 07-09-2011, 11:54 AM
Thanks for the info. I ended up buying a ham transceiver, an ICOM IC-208H. It's more bang for the buck for my purposes. If I ever decide to get a land mobile radio, an 8 or 16 channel rig will do, since now there will be a ham mobile next to it both at home and in the pickup.
Old 07-22-2011, 5:54 PM
btritch's Avatar
I just purchased and 8180 UHF. I will be using it for UHF LTR Trunking for my local road dept frequency (Since I'm allowed to use it when the county storm chases) and I have everything to set it up. It will just be replacing my current 863G. However, I needed to know if the 8180 would do UHF Conventional LTR Trunking.. But I think I answered my own question as it will. Someone correct me if I'm wrong?
Brian
Northeast Arkansas
Old 07-22-2011, 6:49 PM
Metrofire31's Avatar
BTRITCH - I can tell you that my TK-7180 will do VHF LTR trunking so I see no reason why the 8180 wouldn't do the same for UHF.
Let me second the above posts about the software being easy to use. Programming is o simple and easy to change when you need to. However, I may be doing something wrong, but I question the earlier post about channel capacity. I believe its capacity is 128 channels, not 512. If I'm wrong someone please correct me.
Let me say to the original poster - if you have any problems, shoot me a PM and I will help you.
"Metrofire31"
Atlanta
WQIT636
Metrofire31
WQIT636 - Atlanta
Old 07-22-2011, 8:29 PM
Hey Guys - I posted too quick. As it turns out, I have the TK-7150, not the 7180, so it probably is 512 channels. But, they both use the same basic Kenwood software and it's VERY user friendly.
Metrofire31
WQIT636 - Atlanta
Old 10-03-2011, 6:16 AM
Default Need help
I have a TK-7180H and a TK-880H
I have a programming cable I used for other Ham Rigs and made an adapter to plug
into the mic input of the radios.
Using the KPG-49D software it works perfectly with the TK-880H.
I can read and write frequencies to the radio and verify my writes
by reading them back and by seeing the names of the new channels on
the display.
Using either the KPG-89D or KPG-96D software I get an error message
telling me to check the Model and Com connection.
On the face of the radio it displays the word "PROGRAM" when
I try to read but then the computer displays the error message.
Should I assume the RS232 to TTL adapter I am using is good since
it works for the TK-880H and assume something is not right with the radio
and or software?
Any help would be appreciated.
Ken
Old 10-05-2011, 10:56 PM
"Should I assume the RS232 to TTL adapter I am using is good since
and or software?"
Some Kenwoods REALLY hate it when you use adapters on them. I use a Cheap $20 programming cable and oddly enough the older Kenwoods (780, 980, 760g)aren't too fond of it but they read and write on the 2nd or 3rd attempt. The newer models read and write just fine. If you can eliminate the adapter then it should work with the 7180.
Old 10-17-2011, 12:47 PM
Default Kenwoods
When I "write" to my TK-7150/8150s, I almost always encounter the "RETRY" error message on the 2nd and 3rd attempt. Most often, I'm able to "write" on the 3rd attempt and I've never had it fail completely. I used a Radio Shack adapter cable RS232-USB along with the TK-7150/8150 programming cable.
As a footnote - I wish every radio and scanner I have was as easy to program or re-program as my Kenwoods.
Metrofire31
Atlanta
WQIT636
Metrofire31
WQIT636 - Atlanta
Old 10-23-2011, 11:47 PM
Raptor05121's Avatar
Metrofire31
Atlanta
WQIT636
agreed. I love programming my radios. takes up to 30 seconds just to add a channel or change the text on the display. love Kenwoods
Base: Kenwood TS-940SAT on Solarcon IMAX-2000
Mobile: Kenwood TK-7180HV on Laird VHF roof mount
