Go Back   The RadioReference.com Forums > Commercial and Professional Radio > Kenwood Forum
Kenwood Forum For discussion of land mobile radio products manufactured by Kenwood. This is to include the TK(R) and NX(R) series radios and their associated accessories. This forum is not for the TM series; use Amateur Radio Equipment.
Old 02-15-2012, 4:02 PM
Default TK-3180 Programming Issues
Hello all,
Just got a used TK3180, and hopefully someone can help me out with an issue I'm having trying to program it.
I'm using a cable with a serial port from Wiscomm, and can't get it to even read the info from the radio. I first tried a laptop running Windows XP with a Prolific USB to Serial adapter, and got the message "Check all connections and COM port settings". After that, I tried a desktop computer (also running Windows XP) with a real serial port built in, and got the same exact message.
Anyone know what's going on, or any advice? I'm starting to think it's a cable issue....
Old 02-15-2012, 4:53 PM
Originally Posted by ffemt134 View Post
Hello all,
You need to make sure the program is set to the com port your connecting the cable up to. I would start with the XP machine and make sure you know where the software and cable connections are. Sometimes other programs hog the first couple of com ports and you don't know it.
Jim
Old 02-15-2012, 9:16 PM
Yep, I made sure the COM port settings in the software matched what the cable was plugged into.....unfortunately, no luck.
Old 02-16-2012, 5:30 PM
Raptor05121's Avatar
Send a message via AIM to Raptor05121 Send a message via MSN to Raptor05121 Send a message via Yahoo to Raptor05121 Send a message via Skype™ to Raptor05121
Well then its either the cables or the connection on the radio.
Old 04-13-2012, 9:56 PM
Make sure you have the drivers for the programming cable, and then check your connection to the radio. Sometimes when I have attached cable to the portable, I have to loosen it a little, then tighten it back down.
Old 06-02-2012, 6:33 PM
Is your cable a USB or DB9 Serial?
Some of the DB9Serial to USB Adapters are very sensitive.....(aka dont work)
Kmacinct....
