Go Back   The RadioReference.com Forums > Commercial and Professional Radio > Kenwood Forum
Kenwood Forum For discussion of land mobile radio products manufactured by Kenwood. This is to include the TK(R) and NX(R) series radios and their associated accessories. This forum is not for the TM series; use Amateur Radio Equipment.
Old 09-26-2012, 2:51 PM
Default KPG 111D Software Questions
Is there a copy and paste feature in the KPG 111D software? Like for moving channels around. Also is there a print feature?
Old 09-26-2012, 5:59 PM
yep, under file select "print".
as for copying, and pasting - just select what you'd like to copy, by highlighting it and hitting control + C on your computer to copy. then delete what you don't want, and move it down.
hope this helps!
Old 09-26-2012, 8:47 PM
Can you simply print the list of channels in a radio?
Old 09-26-2012, 9:53 PM
Kirk,
It's very easy to copy and paste a channel (or group of channels) by dragging the curser down the far-left column to highlight the channel(s) you want to move. For example, if you want to move channels 5, 6 and 7 just click on the 5 and drag the curser down to 7 so that all three are highlighted. Then you can right-click (or control-c) and copy those three channels. Once they're copied, you can click on the new channel number where you like to paste/move them.
Not sure why my reply posted twice. Sorry...
Old 09-26-2012, 9:59 PM
Thank you both, that's simple enough.
Old 11-18-2012, 10:33 AM
Has anyone found a way to copy and paste data from one .dat file to another .dat file? Kenwood says this cannot be done and from what I can see they are not lying as I have tried to do it and it wont work. Is there anyway to accomplish this? I want to move a bunch of data from one .dat file to another and dont want to have to type it all out manually to the other .dat file.
Doug
Old 11-18-2012, 11:21 AM
Doug, not as straightforward as you'd hope, but it is possible to export dat files to itm files and use a text editor to add/remove frequencies to combine them with a bit of work. You can then import this file as the new combined file. There doesn't seem to be any way of pasting into the software ;-(
Old 11-18-2012, 12:31 PM
No simple way to print. Kenwood dropped the ball on this one. It does not print like vertex software, it takes A LOT of paper to print a radio like a TK-380, LOTS and LOTS if you use lots of channels
Interoperatablity is not a technology it is an attitude!!!
Old 11-18-2012, 6:04 PM
the best way i find to do it is to hit the print screen key then open word and paste it, crop it and drag to the size i want.
i keep a blank word doc on my desk top just for this.
Old 11-20-2012, 3:21 PM
Default another question
Hello
Where in the KPG I will find talkback option?
VY73!
Steve
Old 11-20-2012, 9:45 PM
In the scan features I think
Old 11-21-2012, 10:11 AM
Default talkback
Maybe my question is not precise. I ask about the function which in Idas is called talkback - for ex.:a radio set in NXDN mode may respond if the FM modulation signal is received ( I can change time for respond).
I do not know if this feature is in Kenwood ???
Vy 73!
Steve
Old 11-21-2012, 9:16 PM
Go to the following
Edit-Optional Features-Common Page 1-Signalling Reset Timer
Setting any time interval other than zero will cause the radio to respond to either an analog or a digital call in the appropriate mode if answered during that time period.
Channel must also be programmed for Mixed Mode.
It works great.
Old 11-22-2012, 10:06 AM
Dear baycomm.
Your explanation is fully satisfactory.
Thank you very much.
Steve
