Go Back   The RadioReference.com Forums > Commercial and Professional Radio > Kenwood Forum
Kenwood Forum For discussion of land mobile radio products manufactured by Kenwood. This is to include the TK(R) and NX(R) series radios and their associated accessories. This forum is not for the TM series; use Amateur Radio Equipment.
Old 01-23-2013, 11:18 AM
Default Kenwood NXR 700
When using a Kenwood NXR 700 in simplex mode, will the external antenna relay from a TKR 750 perform correctly or is there an alternate model, or can simplex only be accomplished with two antennas
Old 01-23-2013, 2:06 PM
mmckenna's Avatar
The NXR repeaters have programmable pins on both the 15 pin molex connector and the DB-25 connector on the back that could be set up to control an antenna relay.
However, the NXR-700 will allow you to use a single antenna. From the service manual:
3-4. Antenna switch
If a common antenna is used for the transmitter signal
and receiver signal, switch transmitter and receiver signals
by connecting CN19 to the RX Unit.
If different antennas are used for the transmitter and receiver,
it functions as an On/Off switch for the transmitter
circuit.
I don't have one of these units in front of me right now, so I can't open it up and see how easy it is (or not). I can see the CN19 connection on the drawings, but I don't know what type of connector it is. The description is sufficiently vague.
Old 01-23-2013, 8:00 PM
ramal121's Avatar
You basically cut the coax behind the RX BNC connector, strip it and solder it to lands on the final board. I think there is a jumper or two also to enable the pin diodes. This will make the TX connector common for T/R. My docs on this are at the other shop. May not get back there for a while.
The fat one will never die! (http://www.kfat.com/)
