Go Back   The RadioReference.com Forums > Commercial and Professional Radio > Kenwood Forum
Kenwood Forum For discussion of land mobile radio products manufactured by Kenwood. This is to include the TK(R) and NX(R) series radios and their associated accessories. This forum is not for the TM series; use Amateur Radio Equipment.
Old 01-31-2013, 7:47 PM
Default NX 200/700 programming
I have a NX 200 and 700, I have the 700 all programmed the way I want it and I just got a NX200. I have tried copy/pasting the codeplug data from one to the other with little (read) no success. Any pointers? I don't think my fingers can take doing another 6 zones and 30+ Ch. in each.
Thanks in advance,
Colin
HT-1250, PR-400, MCS-2000, CM-300, CDM-1550,1250, TK 7180, TK 2312, Minitor V, BCT-15X BCD-996XT
FF-II, EMT-B. Radio Nerd. Feed Provider.
Old 02-01-2013, 5:01 AM
Send a message via AIM to Josh Send a message via Yahoo to Josh
Load the data from the first radio, then click the "model" drop box at the top of the programmer. A window appears with various radios. Change it from NX700 to NX200 and it should change models.
You'll have to set radio-specific things to your liking, but aside from that the frequency data should be good to go.
Old 02-01-2013, 9:22 AM
Thanks for the reply, seems to have mostly worked, except I can only access 16 channels from the rotary knob. I know it is only designed for 16 thus the little plastic bar on the base of the knob that I removed right off the bat. When I had my initial codeplug in there, i had 20 something channels in there and had no problem going through all of them. Now it gets to the 16th channel and starts at the beginning, even though it scans the channels past 16.
Thanks again,
Colin
Old 02-01-2013, 10:00 AM
Wirelessly posted (Opera/9.80 (Android 4.0.4; Linux; Opera Mobi/ADR-1301080958) Presto/2.11.355 Version/12.10)
You can set the knob to be continuous or end stop under the radio options.
Radios I have: XTS2500 Model 2 in 700/800 and VHF. Homepatrol 1.
Old 02-02-2013, 6:40 PM
how do u remove the plastic stopper??
Old 02-02-2013, 7:37 PM
You have to use a spanner that can grasp both sides of the nut in the slots, remove the nut, then the plastic stopper, and replace the nut.
Old 02-02-2013, 9:07 PM
Thank you.... All done Sweet
