Go Back   The RadioReference.com Forums > Commercial and Professional Radio > Kenwood Forum
Kenwood Forum For discussion of land mobile radio products manufactured by Kenwood. This is to include the TK(R) and NX(R) series radios and their associated accessories. This forum is not for the TM series; use Amateur Radio Equipment.
Old 02-14-2013, 2:51 PM
Default Poor distance of Kenwood TK-33xx
We have a number of TK-32xx and 22xx radios. With them, we cannot communicate between our two buildings, less than 100 feet apart.
A pair the the cheap FRS radios, on 500 milliwatts will.
What is wrong with the commercial radios?
Old 02-14-2013, 3:15 PM
Are they all setup the same? If you had them withing 10 feet, can you talk back and forth?
If not then they need to be looked at to be sure they can talk to each other.
Old 02-14-2013, 8:29 PM
mmckenna's Avatar
One thing to consider is that some people don't understand how to treat a radio. They'll often use the antenna as a handle, beat the snot out of it, etc. On some radios, not sure about these, it's common for the antenna mount to become separated from the circuit board. Result is that the radio works poorly.
Not saying it's the cause, but I've seen a lot of radios with this issue. No matter how many times you tell people to be careful with the radio, they still treat it like crap.
I also had a radio once that the amplifier transistor was toast. The radio put out about 30 milliwatts when keyed up. This one was brand new, so it was a factory issue. Sometimes a damaged or missing antenna can do this, or someone using a UHF antenna on a VHF radio, and vice/versa.
I agree with Cabletech, they probably need to be looked at closely.
Tags
frs, kenwood tk 33xx series, performane
