TK-805D "remove from scan"
D
DaveNF2G
Guest
The instructions that I found online say that, to remove a channel from scanning, the procedure is:
Take the radio out of Scan mode.
Dial to the channel to be removed from scanning.
While holding the SCAN button, press the A/D (Add/Delete) button.
This procedure has no effect on my unit. The ADD symbol remains on the display and the channel continues to be scanned after several attempts.
Does anyone know what else I should be doing?
D
DaveNF2G
Guest
I figured it out and decided to post here in case anyone else should have the same problem.
In order for the removal procedure to work, it has to be enabled in the Options Menu by switching item 4 to On.
