kenwood tk 7150 low audio output
radioman16
mount ayr
i have a kenwood tk 7150 when you tx the receiving radios have to turn the volume up real loud in order to hear and it is still quiet. i have changed mics and was wondering if any one else would know what it could be?
T0mSmith
Are all the radios programmed with the same channel width? Sounds like your radio may be programmed to use narrow channel, while the receiving radios are set to a wide channel. Just a thought.
BirkenVogt
BirkenVogt
We just got a batch of them and the max. dev. on narrow is set to low from the factory. I think they only modulated 1.5 kc off the bat.
radioman16
mount ayr
yes they are all programed on the same. currently using wide band except for one channel. and the other radios are programed with the same data off the software.
What kind of vehicle are they being used in? If it is a noisy environment maybe try an external speaker.
Sent from my SAMSUNG-SGH-I337 using Tapatalk 2
