Go Back   The RadioReference.com Forums > Commercial and Professional Radio > Kenwood Forum
Kenwood Forum For discussion of land mobile radio products manufactured by Kenwood. This is to include the TK(R) and NX(R) series radios and their associated accessories. This forum is not for the TM series; use Amateur Radio Equipment.
Old 12-08-2013, 12:21 PM
wcu02mpa's Avatar
Default TK-7150 6-pin plug
Can someone tell me the 6-pin accessory plug part number (from Mouser) for a TK-7150/8150? or any other place this can be obtained? Also making sure I jumper pins 5-6 for internal speaker??
I was trying to daydream, but my mind kept wandering.
Old 12-08-2013, 12:42 PM
kc0wkp's Avatar
Yes pin 5 and 6 are correct for the internal speaker jumper.
This should be the correct item for that radio
03-09-2062 Molex | Mouser
Also hereis the service manual which will give the Pinout configuration for the radio
http://www.ko4bb.com/Manuals/Kenwood...-7150_8150.pdf
kc0wkp
"If it don't glow, don't buy it"
Old 12-10-2013, 10:50 AM
wcu02mpa's Avatar
Default Pins??
I completely forgot to ask about the pins. I have some pins that fit the X30 series' plugs. Are they the same or which Mouser pins are correct? Also thanks KC0WKP for connector info...
I really like the TK-7150 radio; underated and can be bought for really cheap. I got one for $100 delivered from fleabay and a mic was included. All I needed is the connector. I found a remote kit for less than $40 and I already had a remote cable. I think this is going to replace my analog spectra in my vehicle.
Old 12-10-2013, 5:34 PM
kc0wkp's Avatar
I am not sure about the pins I believe they are the same.
As far as them being cheap and underrated, there is a reason for that. The radio has a known flaw and a serious one at that. The radio will randomly put out a long "0" DTMF tone on channel one. There is no warning and the user has no indication of the transmission.
This is just something to note, I do not know if there is a fix out there for this or if there is a newer version that this has been fixed in.
kc0wkp
Old 12-17-2013, 8:47 PM
wcu02mpa's Avatar
Default Wrong plugs
Those are not the right plugs. They are too big. I have plenty of them if anyone needs one. Can you verify which ones are the right ones??
Old 12-18-2013, 10:53 AM
ramal121's Avatar
Kenwood uses Molex connectors of the 0.062 size. Pins are all the same, shell varies with the number of circuits.
Old 12-18-2013, 3:34 PM
wcu02mpa's Avatar
Default Actual connector
The above connector is not correct. I am still looking for correct part. Thanks
Old 12-18-2013, 4:40 PM
ramal121's Avatar
View List
Old 12-20-2013, 8:02 AM
wcu02mpa's Avatar
Still not sure exactly which plug I need......
Old 12-20-2013, 9:35 PM
Contact your local Kenwood dealer and tell them you need the 6 pin accy connector with pins.
They are available thru a dealer. +/- $5.00 each
Old 12-21-2013, 9:26 AM
ramal121's Avatar
All the socket plugs in the link I gave will fit. The difference is color and whether they have mounting tabs or not.
Old 12-22-2013, 3:23 PM
wcu02mpa's Avatar
Default My mistake
Ramal121....I see. Sorry for confusion
