Kenwood TK 3140 PTT Beep
Res21cue
Res21cue
you need to program that option with the software.
Edit
Optional features
Optional features 2
PTT Proceed Tone - make sure there is a check mark in that box. Default is no checkmark so you need to enable it. Should take about 1 min anf 14 seconds to do this.
rapidcharger
The land of broken calculators.
Just FYI proceed tone only makes a quick split second beep when you key up the radio. It does not beep when you unkey.
If the x140s are anything like the x180s you set up those options by channel. So if you're not finding it in the radio-wide menu check the options by channel.
