k4etn
Hoping that someone out there has seen this issue and can help. One of my 70cm repeaters is a Ver. 1 TKR-850.
Here is the problem: After a unspecified period of time, could be several hours, 20 minutes into a conversation the repeater will not transmit repeat audio. There are no error codes on the display. Rx is fine, QT decode is fine, just no transmit. I do not have a service mic on this machine yet so no idea if local ptt is working.
If you power down the repeater, it will come back up and work just fine. I am not using a external controller and would prefer to use the internal Kenwood controller if possible.
Have checked for cold solder joints and all connectors are secure.
Ideas, theory or what ever would be helpful. When it's working it's a great repeater.
