Programming TK-2402V
iceman977th
Catlettsburg, KY
I ordered a set of TK-2402V16P's to use as radios for a production company. I'm trying to program them using KPG-158D 2.01 and the USB cable. Every time I try to read or write, it gives me the error "Ensure that Model Name and Market Code are correctly entered." ...It is set properly to TK-2402V (K), VHF, but yet I'm not able to read or write to it. Using Win7 64-bit on a Macbook Pro with the latest Prolific USB to Serial driver installed. Any idea what I'm doing wrong? COM port settings are correct. Is there a programming mode for these?
KPG-159DN is the software you want for the TK-2402V. Not sure if that was a type-o or not in your post.
Version 1.03 is the latest, released in September of 2014.
Also, programming with a Mac can be iffy. I've got some Kenwood software running on mine using Virtual Box. I do all the -real- programming with a real PC though.
There isn't a programming mode. You should be able to just turn them on and go from there. Make absolutely sure the programming cable is fully and completely seated into the radio.
Did a bit more digging. KPG-158 is the European/Middle East/Asia version.
If your radios are for that market, then you should be OK.
If not, and the radios are USA market, then you need the 159...
