Constant Feed Disconnect/Reconnecting
I recently moved my Juniata County, Pennsylvania Feed from my house with a cable modem with a wireless router to my ambulance station with a firewall and router. I am streaming multiple streams of the same stream that I'm sending to RR and they have NO problem but the RR streamer will connect and then after about 30 seconds it will disconnect, count down and then reconnect and it continues to do this. The port is 80 and 80 is open through the firewall.
This goes to the admin staff of RR for the feeds, or anyone who has had the same problem - what do I need to do to my server and/or my firewall to get the feed to STAY connected.
Just more info about the other feeds, I'm using TeamSpeak and IceCast to two separate servers on the Internet and they both connect right away without any special ports being opened on my firewall but as soon as the RR feed attempts to connect it constantly disconnects and reconnects. Modem speed is not a problem because it is the same connection I had at my house which is only a mile away. Any help would be greatly appreciated.
