To get rid of the ground loop one of the isolators is a good way to go for our application. Back in the old days of installing high end car audio and also fixing bad installs we would see group loop issues all the time and they always tried one of these $20.00 fixes they do work to a point for what we want I think it will work good enough but for high end audio we chucked them in the trash and found the source of the bad ground and fixed it that way.
To do that at home would cost more than it is worth if you are only using a scanner. I have the same issues but my house is 60 years old and a Tim Taylor School of wiring before I moved in so to say I have bad grounds or no grounds is understatement.
Brian
GRE 500, RS PRO 197, RS PRO 160, RS Pro 528, RS Pro 97 X 2 and RS PRO 2027(this unit is the best for non digital)
