Server maintenance Monday morning around 9:30am Eastern Time
Monday morning at around 9:30am Eastern, we're going to make a behind-the-scenes change to which server old ScanAmerica feeds (and some feeds that were added just after the RadioReference.com transition) are hosted on.
Once we begin making this change there will be a short window of time (20 minutes or so) where all of the affected feeds will appear offline on the website. Near the end of this 20 minutes window you should see your feed (if you're watching the encoder at the time) disconnect from the old server and reconnect to the new server, once that happens your feed will appear online again. If, for some reason, your encoder doesn't automatically reconnect once its connection to the server is severed you'll need to manually force your encoder to reconnect. During the 20 minute window where your feed appears offline on the site even though the encoder shows that it is still connected, don't force your encoder to disconnect and reconnect, doing so could delay how long until your encoder connects to the correct server.
-- Gordon
Listen to RadioReference.com's online scanner feeds on your BlackBerry using BBScanner.
Reason: Updated scheduled time.
