Go Back   The RadioReference.com Forums > Site Administration Forums > Live Audio Administration
Live Audio Administration Administration topics for live audio broadcasting on RadioReference.com
Old 10-27-2009, 12:44 AM
Default couple important questions.
I have a few questions
#1 Why isn't my scannercast connecting to my account, so i can feed?
#2 Are audio feeders, not premium subscribers no more? I was bounced back to a regular member
It shows my feeds on the site, but I am unable to connect using scanner cast. I have reinstalled scannercast and still the same problem.
http://audio3.radioreference.com:80/26442221 Winnebago County Feed
http://tornadolinks.com #1 Tornado & Weather Links site!
Scanners - BC898T, Pro-97, Pro-528, Pro-95, Pro-39
Old 10-27-2009, 12:55 AM
I think i may have found out the answers to my questions.
I wasn't able to use scannercast auto login to RR, but as soon as I unchecked the option to not login to RR and start the broadcast, it let me.
Once i was able to broadcast, i became a premium subscriber again.
I guess i answered my own questions after some trial and error, lol
But i do have a question now, i do a couple feeds. So do i have to manually input the info now, instead of the auto login?
Old 10-27-2009, 01:50 AM
To answer your Scannercast questions, you may want to try this thread.
Beta Testers Wanted: K1PGV's ScannerCast
I believe it was changed today to where if you are actively providing a feed, you will be a premium member. If you are not actively providing a feed, you are not a premium member. You have to be actively feeding a stream in order to get that status.
Old 10-27-2009, 02:40 AM
Chauffeur6's Avatar
Your premium subscription is only active when your feed is active, per the new changes yesterday.
The workaround for ScannerCast is simple: disable the auto-config and start the feed the old fashioned way, by entering the server info. It should already be filled in for those who've run their feed through the program already, so it's not really a big deal. Lindsay is working on a fix for the issue as well.
Old 10-27-2009, 02:46 AM
Hi,
Thanks for the replies.
I like the idea you only get premium status only when your feeding.
I liked the option on auto login on scannercast, hopefully they can work it out and bring that option back.
Old 10-27-2009, 03:00 AM
Chauffeur6's Avatar
Yeah, I can see it being a bit of a hassle if you run multiple feeds. Hopefully Lindsay will have a fix for it soon.
Old 10-27-2009, 07:26 AM
kendrik578's Avatar
Live Audio Administrator
Send a message via ICQ to kendrik578 Send a message via AIM to kendrik578 Send a message via MSN to kendrik578 Send a message via Yahoo to kendrik578 Send a message via Skype™ to kendrik578
Lindsay, will be working on that today.
Kendrik
kendrik578@radioreference.com
Old 10-30-2009, 03:28 AM
I lost one of my feeds. I went to broadcast and noticed it wasn't letting me. So I looked and it is gone. I only broadcasted it a few times when activity was on it (local airport) so i dont know it was because on inactivity or the update.
Old 10-30-2009, 07:29 AM
kendrik578's Avatar
If you had not brought it online in 3 weeks then it was most likely deleted. Dont think the update deleted it.
Kendrik
Old 11-02-2009, 06:34 AM
that feed was offline for awhile. sorry about that.
i usually do the one feed, and the other on occasion
thnx for the reply.
