Originally Posted by Asmitty0010
this may be a dumb question but I cant for the life of me figure out how to view text tags on feeds with them posted as such. I've tried both itunes and winamp as players and all i see is the name of the feed scrolling. What am I doing wrong?
If you're using WinAMP (at least i can vverify this with recent versions) and you are listening to active chatter on a feed claiming to support text tags, but you don't see text tags, then the feed probably isn't really sending the tags. Somebody probably just checkmarked it to encourage more people to listen in, not realizing that 99% of the listeners (based on my own statistics for my feed) could care less about tags and simply use a web browser or WMP.
Or they may think they are sending tags but they are not.
Check out my feed and see if you are seeing tags on it when using WinAMP. This one is definitely sending tags -
Jefferson County Police, Fire, and EMS Live Scanner Audio Feed
If you don't see them when there is an audio transmission, then I guess there is something amiss with your winAMP. But out of the box it should work.
