| Live Audio Feed Administration Administration topics for live audio broadcasting on RadioReference.com. This forum is for feed providers to get support. |
05-28-2010, 1:57 AM
Has a server gone down?
Hi all, has a server gone down at Radio Reference? i cant seem to connect yet all is normal at my end?
i noticed a lot of other streams offline too.
cheers
Matt
05-28-2010, 2:01 AM
Same. My feed can't be broadcasted on audio1.radioreference.com:80
05-28-2010, 2:08 AM
yeah im on audio 1 too must be that server. its been gone for nearly an hour now. a quick check around shows a fair few offline.
cheers
matt
05-28-2010, 2:09 AM
Too bad there isn't any contact us link
05-28-2010, 2:12 AM
not wrong i hope they get onto it soon, its 5pm friday night here gets busy here shortly.
cheers
Matt
05-28-2010, 2:15 AM
Columbus, Ohio Fire and Police feeds are down as well....Hopefully they get it fixed soon..
I apologize for my poor spelling and grammar...
05-28-2010, 2:22 AM
mine is down too. Audio 1 server problems again. Wish there was a way to switch servers. I have recieved about 25 emails about my feed being down from listeners since just before mid-night EST
05-28-2010, 2:29 AM
Same computer feeds two scanners to audio1 and audio6. Audio1 will not connect. Audio6 is working.
05-28-2010, 2:49 AM
I did a remote ping to audio1.radioreference.com from my webserver just to make sure it wasn't my connection. Same thing, ping timeout. audio6 pinged back good though. I think I've always been on audio1... I've always ran tags with my feed as well if that makes any difference.
05-28-2010, 3:11 AM
Same issue here...
05-28-2010, 3:27 AM
I just made it so that the listeners can connect directly to the ScannerCast so they can listen. Hopefully this will work til they can fix the server problem
05-28-2010, 3:45 AM
how do you do that?
05-28-2010, 3:50 AM
Originally Posted by longreach
how do you do that?
Open a port (port forwarding) on you computer. Then on scannercast config tab click on it and you will see SERVER. Enter a stream name, enter description and the port that you opened, place that in the server port, make the Max connections 0 and click on start broadcast. follow the instructions on scannercast's website.
05-28-2010, 4:05 AM
My feed won't connect either, I did take the opp to change to the ScannerCast Software from the RRBroadcast. But same issue,,,, no server response.
05-28-2010, 4:31 AM
yeah only bad part is my scannercast dont let me do that.
cheers
Matt
05-28-2010, 5:03 AM
After trying to troubleshoot for 20 minutes, I find this thread. At least I know I am not the only problem...
05-28-2010, 5:26 AM
Still Down
Mine is still down trying to establish connection.
05-28-2010, 5:59 AM
Audio1 here, as well - down for a few hours now; since about 2am eastern, according to my logs...
05-28-2010, 6:18 AM
We're aware of the problem folks, more to follow.
05-28-2010, 6:38 AM
mine has come back online, cheers and thanks Lindsay
cheers
Matt
