Go Back   The RadioReference.com Forums > Site Administration Forums > Live Audio Feed Administration
Live Audio Feed Administration Administration topics for live audio broadcasting on RadioReference.com. This forum is for feed providers to get support.
Old 06-12-2010, 2:54 PM
Default scanner cast problem
i cant get scanner cast to work , i have an xp machine , i download the program unzip it to the c drive , every time i run it i get the program has encountered a problem and needs to close.
anyone have any suggestions?
pete
Old 06-12-2010, 3:52 PM
richtidd's Avatar
Live Audio Administrator
pete
You have two feeds.
You can run several instances of ScannerCast & you will need a sound card for each feed.
Just give each copy of ScannerCast a different name & place each in different folders.
Each ScannerCast points to a specific sound card.
Richard Tidd
Broadcastify.com
richtidd@broadcastify.com
My online scanners:
SMCo, Tuolumne Co
Old 06-12-2010, 4:18 PM
the feeds are 40 miles apart lol 2 different locations
pete
Old 06-12-2010, 9:15 PM
I recommend making sure you have Microsoft's .NET Framework (v2.0) installed, you can get it at Download details: .NET Framework Version 2.0 Redistributable Package (x86)
-- Gordon
Listen to RadioReference.com's online scanner feeds on your iPhone or iPad using Scanner Radio Deluxe or on your Android phone or tablet using Scanner Radio.
Old 06-14-2010, 5:32 PM
PeterGV's Avatar
K1PGV, ScannerCast author
We can help you a lot more if you post all the details of what ScannerCast says when it fails.
Gordon is right, of course. The first step is to ensure that the .Net Framework V2.0 is installed. This is a prerequisite to running ScannerCast.
Peter
K1PGV
Old 06-17-2010, 11:18 AM
I am having the same problem, .NET framework is installed on my computer, i have tried installing this software on 3 machines now and it fails to launch on all of them bringing up the crash window on xp. (window with the option to send report to microsoft)
Old 06-19-2010, 8:24 AM
PeterGV's Avatar
We want to help you, and we probably CAN help you, get ScannerCast running. It's running on hundreds of machines. I've, personally, never seen a Windows systems (from Win2K and later) that it doesn't run on.
The problem is that saying "it doesn't work" really doesn't give us any clues that might help us to help you solve the problem. Just saying "it fails to launch" is a bit like posting a question that reads "Please help me, my car doesn't work" -- WHAT doesn't work? Will it start? Will it run for a while? Is the battery charged? Does the engine turn-over? Is it getting gas? Is it getting spark?
It's the same with ScannerCast: What EXACTLY happens and when? What are the symptoms. What type of scanner? What type of sound card? What do the messages say? What does it say in the DETAILS tab of the messages that are displayed?
Also, in this case, immediately after the problem -- and before starting ScannerCast again -- there should be a file named scannercast_ERROR.log created in the same directory as ScannerCast.exe -- If that's the case, please post the complete contents of this file.
Also, knowing which version of ScannerCast you're having a problem with would be very useful. On the folder into which you've installed ScannerCast, right-click on ScannerCast.exe and select "Properties", and tell us the Product Version that's displayed on the "Details" tab.
Peter
K1PGV
Old 01-21-2013, 10:25 AM
microwave's Avatar
Default Will a newer version of .NET work?
I am using .NET 4.0 and I'm getting and error that says ' Unable to find the version of the runtime to run this application' Could this be the issue?
Old 01-21-2013, 10:39 AM
Yes, if you don't also have .Net 2.0 installed.
Old 01-25-2013, 6:00 PM
I'm having an issue with Scannercast also. When I hit start broadcast, it is telling me "there are no feeds assosiated with the user name deevon911" It was just working 5 mins before, but I had to restart my computer. Anyone else have an issue with this before?
Old 01-25-2013, 6:52 PM
richtidd's Avatar
I sent you several e-mails but they all bounced.
Please reply to me at this e-mail address with your working e-mail address:
Richard Tidd
Broadcastify.com
My online scanners:
SMCo, Tuolumne Co
Old 01-25-2013, 7:01 PM
Default Re: scanner cast problem
Will do.
Done, not sure why they bounced.
Sent from my ADR6350 using Tapatalk 2
