Go Back   The RadioReference.com Forums > Site Administration Forums > Live Audio Feed Administration
Live Audio Feed Administration Administration topics for live audio broadcasting on RadioReference.com. This forum is for feed providers to get support.
Old 09-10-2010, 7:56 PM
Default Feed Issue
I was notified that my feed was down. I came and checked and it appeared to be up and running. I stopped and restarted the feed and got this error message:
Failed to connect to RR Server - Audio6.radioreference.com/993312348
A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connecte host has failed to respond 184.73.220.163:8000
Retry: continues trying connect (no further error messages will be displayed
Cancel: stops trying to connect to the RR server and mount point named above
Any ideas or suggestions?
Old 09-10-2010, 8:27 PM
Live Audio Administrator
The audio6 server is currently offline which is why you're not able to get your feed back up.
Lindsay has been notified about the problem.
-- Gordon
Listen to RadioReference.com's online scanner feeds on your iPhone or iPad using Scanner Radio Deluxe or on your Android phone or tablet using Scanner Radio.
Same here in Eau Claire, WI This appears to be a problem on RR's end. A number of other sites here in Wisconsin are also DOWN.
Old 09-10-2010, 8:49 PM
Just started having an issue...How long might it be down for
Old 09-10-2010, 10:54 PM
The server is now back up.
