Originally Posted by WR9A
Yes, I understand how the process works and have my feed up and running with Scannercast. But what I don't understand is how Broadwave Audio Stream Server can be used to provide feeds to RR. There isn't any provision in the software that I can find to specify a location to "push" it to.
Broadwave is an audio streaming server and I can connect to it on my own machine, but is it able to be used to provide feeds to RR? After being mentioned on the RR Live Audio wiki as alternate software to use, one would assume it can be used to provide the streams to RR.
I have no problem continuing to use Scannercast, but it would be nice if I could use Broadwave to feed multiple streams to RR.
Stephen M. Parker
What I sent was for a general push feed to us.
You are correct in that Broadwave is server software.
This means a different connection we make to you to pull the feed from you.
I will e-mail your separately with the detials.
However, why not just use another instance of ScannerCast?
See here for how:
Multiple Feed Configuration
