Go Back   The RadioReference.com Forums > Site Administration Forums > Live Audio Feed Administration
Live Audio Feed Administration Administration topics for live audio broadcasting on RadioReference.com. This forum is for feed providers to get support.
Old 02-20-2011, 6:10 PM
scannerface27's Avatar
Send a message via Yahoo to scannerface27
Exclamation oddcast
please help get my feed back... new computer.. oddcast will not connect keep gettuing unable to connect to socket problem.....worked fine on my last computer feed has been down for two weeks...dont know what is wrong ..will give number to call to anyone in admin to please help with this situation.
2-pro-92's-bcd396xt-pro-163-bc200xlt..
c.j.u.h.s.d. school officer."10-6 ALL DAY"
scannerface 27-feed prov-system 1-sbso
Old 02-20-2011, 6:15 PM
I am noticing that the line in appears next to the mic..for audio... but the source will only select master volume.. will not let me switch to line in in that box
Old 02-20-2011, 6:35 PM
Are you sure your config settings, such as your mountpoint, server type, server ip, and password, are correct in Oddcast?
RS PRO-18, RS PRO-197, RS PRO-2052
Fire & EMS feeds: http://www.broadcastify.com/listen/feed/527 & http://www.broadcastify.com/listen/feed/3331
Old 02-20-2011, 6:39 PM
thats what i need help with..never had a password before
Old 02-20-2011, 10:21 PM
Dubbin's Avatar
If your feed has been down for 2 weeks they may have deleted it.
Dwayne
My Scanner Feed
Old 02-21-2011, 1:00 AM
richtidd's Avatar
Live Audio Administrator
Your feed has not been deleted.
It shows as active but offline.
If you want to continue to use OddCast, please see here for the set up instructions: Oddcast/Edcast Setup by Oddsock.org
This is a download of a new OddCast that you can choose to use of not but it is the included instructions you want to follow.
Richard Tidd
Broadcastify.com
richtidd@broadcastify.com
My online scanners:
SMCo, Tuolumne Co
Old 02-21-2011, 5:01 PM
Richard thanks, I think it is just the settings on my computer maybe..shows master volume, where i should be able to choose line in, mic, whatever. but will not show those others to switch, only master volume
Old 02-21-2011, 5:32 PM
Cool
Richard,thanks its working now but still is showing master volume, but how do i mute the playback, my computer is weird or get the master volume, to let me pick between master,linein,mic, etc
Old 02-21-2011, 6:11 PM
richtidd's Avatar
You select the actual mic or line input on the computer sound card.
Then on the OddCast main page is where you select the sound card of the computer. Right there to the right of the microphone image under the the section called Live Recording.
Richard Tidd
Broadcastify.com
My online scanners:
SMCo, Tuolumne Co
Old 02-21-2011, 6:48 PM
Thanks Rich, again I got it working it was a setting under sounds-speakers to go in and actually mute the tab for line0in.. the other prob is the box next to where you select line in--the other one use to give you a choice line-in,mic, or other. for some reason mine shows master voluime only..but its working
