| Live Audio Feed Administration Administration topics for live audio broadcasting on RadioReference.com. This forum is for feed providers to get support. |
06-28-2011, 12:21 AM
Many Feed Offline
Thought I would start the post that there are a large number of feeds offline!
EDIT: And of course I just happened to put feed instead of feeds. Oops!
06-28-2011, 12:24 AM
Same here,,,, my scanner is still broadcasting but the player keeps searching (or buffing or scanning lol)
Never play leapfrog with a unicorn.
06-28-2011, 11:06 AM
Hey Folks,
Not sure if it is the same issue brought up in this thread:
http://forums.radioreference.com/liv...g-offline.html
but we have a feed that keeps showing offline yet when we log in to the remote system, ScannerCast shows to be broadcasting fine. However, a start and stop of ScannerCast, will usually get the feed to show online again for a little while. Also, if we have the feed "bookmarked" in an app like WinAmp, the feed continues to play even if it shows offline here at rr.com.
Anyone have any thoughts?
Thanks!
06-28-2011, 12:59 PM
Error connecting to RR
Window Title: RR Auto Config Error (302)
Error accessing RR
The request failed with HTTP status 417: Expectation failed.
Internet connection otherwise OK. This is on a dedicated box that had not been touched in over a year.
Sony ICR-120
SBE Sidebander II
06-28-2011, 1:10 PM
Live Audio Administrator
Lindsay has advised that everything appears to be ok now.
Kendrik
kendrik578@broadcastify.com
12-07-2011, 8:58 AM
feed problem
Hi
I am the feed provider for the Gloucester county in eastern canada (New-Brunswick). this morning, i notice that scannercast was still broadcasting but the player ( web player in RR ) is green = online with a red X. counter is a 00:00.
any idea?
thanks
12-07-2011, 9:06 AM
Just to confirm, my feed 4787 is doing the same. I tired to add a status update and it did not show for at least five minutes.
Scanners currently in use: Uniden BCT15x, BCT8, RS Pro-163, & PRO-94
12-07-2011, 9:12 AM
thanks for info........so i'll connect back my wires to the soundcard....
must be a server problem or something
thanks again
12-07-2011, 9:16 AM
thanks again
Yes, there is an issue right now and it being looked into.
Thanks!!
Kendrik
12-07-2011, 9:18 AM
thanks again
The feed is working again. Also, try Firefox. It seems as if the problem might be JAVA related. Just a thought.
12-07-2011, 9:32 AM
Well that was fast.......ok...everything is back to normal again........
thanks for the reply guys
12-07-2011, 11:37 AM
Detroit Fire is still offline too.
''Life's tough ........ it's even tougher if you're stupid.'' -- John Wayne
