Go Back   The RadioReference.com Forums > Site Administration Forums > Live Audio Feed Administration
Live Audio Feed Administration Administration topics for live audio broadcasting on RadioReference.com. This forum is for feed providers to get support.
Old 11-01-2011, 12:25 AM
Default Audio Graphs on two Web Players
I have two feeds and used to see independent audio graphs on two web players, each playing a different feed. Now both feed graphs show identically as if both feeds are summed together on both players. What has changed? I like both players to act independently and not show the same combined audio feed graph.
How can I fix it?
Old 11-01-2011, 6:41 AM
kendrik578's Avatar
Live Audio Administrator
This is a common problem that happens when you have two webplayers going at the same time. Use something other than the webplayer (Itunes, Winamp...etc)
Kendrik
kendrik578@broadcastify.com
Old 11-01-2011, 12:31 PM
wrenchmonkey's Avatar
If you left click the graph, it will switch back to the "classic" bars. I don't like the new audio graphic bars, they don't work with stereo or multiple feeds.
BCD996T/Pro-197, ARC996/ARC500, K1PGV's ScannerCast on Neoware E140 Thin Client (1 GHz/1 GB/1 GB), Yeasu VX-7R and Mirage BD-35 amp, 14 Ahr/12 VDC UPS.
Last edited by wrenchmonkey; 11-01-2011 at 12:35 PM.. Reason: clarify what to click
Old 11-02-2011, 12:07 AM
Yes! That fixed it. One click on each graph changed them from summed channels audio spectrum display to independent volume displays. Thanks!!!!
