Go Back   The RadioReference.com Forums > Site Administration Forums > Live Audio Feed Administration
Live Audio Feed Administration Administration topics for live audio broadcasting on RadioReference.com. This forum is for feed providers to get support.
Old 03-19-2012, 2:15 PM
Default Multiple sound cards on 1 PC
I have an older HP desktop, running XP, which I'm running one feed on at this time. The desktop is using its internal sound card.
I have a new Soundblaster external PCI card.
Can I install this external sound card on my PC, and still use the internal card, to be able to send out two feeds from one PC? Will the external disable my internal when I install it?
Thank you,
Alan McClain
ka4bni@ka4bni.com
Old 03-19-2012, 3:36 PM
You should be able to. Scanner Cast will let you choose which one to use. I run 3 sound cards in a PC and it works great.
Thank you,
Alan McClain
ka4bni@ka4bni.com
Old 03-21-2012, 2:23 PM
Tryton's Avatar
do you use 3 of the same brand or do you vary?
Equipment: Uniden Bearcat BCD996XT X 2
________________________________
K1SPL
Old 03-21-2012, 2:29 PM
nunyax's Avatar
Speaking for myself, I run different brands. On 1 Windows XP PC I run:
onboard SoundMax audio
Creative Sound Blaster PCI
Turtle Beach Santa Cruz PCI
Generic ALS4000 PCI
plus 4 of the cheap USB sound cards on a hub
Works great. Hope that helps.
73 de KQ4XL
Joe
Just one of the "little scanner people."
Old 03-21-2012, 2:30 PM
I use 3 different brands to make things easier. The one built in on the mobo, pci and a usb one. I have not tried using two of the exact ones but that would be a good experiment to try one of these days. The PC is running WinXP and works really well. I use two of the sound cards for scanner streaming and the other one for recording of various audio from an FM tuner or satellite receiver.
Old 03-21-2012, 2:32 PM
Generic ALS4000 PCI
Now that's a streaming beast!!
Old 06-04-2012, 4:57 PM
Can someone tell me, if I use multiple sound cards, what software do you use?
Old 06-14-2012, 5:56 PM
xeno194's Avatar
All the packages will support what recording audio input you will choose to send the scanner audio into. I use radiofeed ProScan i have 3 instances of this app running on my windows xp audio server with 3 usb sound cards. I have zero issues with this configuration. Mike Xeno: FEEDS
996T/RTLSDR/BC244CLT X3/UV3R+/UV-5RE/Afedri SDR Net
http://www.mikexeno.com
