if you goto the start button and click on it, bring up a menu list, click on control panel, in control panel you will see "sounds and audio devices" dubble click on that icon, on the next window that pops up you will see on the top a tab called "sounds" click on that and you should see a "sound scheme" , from the drop down menu select "No Sounds", click on "Apply" and then "OK", thats it... your good to go!!..
