Go Back   The RadioReference.com Forums > Site Administration Forums > Live Audio Feed Administration
Live Audio Feed Administration Administration topics for live audio broadcasting on RadioReference.com. This forum is for feed providers to get support.
  #41 (permalink)
Old 02-01-2013, 7:43 PM
Default Raspberry Pi for feeding
Feed computer for under $60? Yes.. see my post here:
Standalone Client Computer
  #42 (permalink)
Old 02-02-2013, 7:18 PM
Send a message via AIM to whgwvscanner Send a message via MSN to whgwvscanner Send a message via Skype™ to whgwvscanner
I forgot to mention I got my new feed computer! I will have to post my specs later.
  #43 (permalink)
Old 02-05-2013, 5:00 PM
Ok, I have come to the conclusion that I must get my scanner feed off of my server. It causes too many issues when trying to get the feed to resume automatically on a reboot, and I still haven't figured out why the USB link crashes after a few hours.. And now my USB sound card does not appear to be working right..
So I scrounged together an old Pentium 2 box and got XP installed on it.. Now hearing the old hard drive cranking away I am thinking maybe instead I should run a small Linux install (I have a few of those IDE-CF adapters and a couple 2GB CF cards laying around but I would never use them for a Windows install - the paging would burn the flash mem out in a matter of months).. I am useless at Linux though unless I can have a list of directions to follow to make it do what I want - which I have found for the most part.. However, I did not see anything related to getting Alpha tags through a Linux streamer. Every thread where someone has asked about it has zero replies.... I have a Pro 197 with the older orange USB adapter.
Does such an animal exist? If so is anyone doing this? Can you walk me through getting it set up and working? Or am I better off just keeping it a Windows box with ProScan? I know XP is pushing the limits of a P2, but streaming will be its dedicated task - I won't be using it for anything else.
  #44 (permalink)
Old 03-05-2013, 10:47 PM
Using config file: /usr/share/doc/darkice/examples/darkice.cfg
Using ALSA DSP input device: pulse
Using POSIX real-time scheduling, priority 98
DarkIce: LameLibEncoder.cpp:75: lame lib opening underlying sink error [0]
thats what i get im closer but not there yet running ubuntu 10.04 any help will be nice been running linux since late 2002 but server stuff is a pain ;/
  #45 (permalink)
Old 03-05-2013, 10:53 PM
Bellingham_Scanner's Avatar
Means Darkice can not connect to RR server.
Check your config and make sure you have your mount point and password correct
  #46 (permalink)
Old 03-05-2013, 11:03 PM
never mind i figged it out did alot of gooleing with each error my station up again running on ubuntu 10.04 sounds pretty good thanks for the ideas too
  #47 (permalink)
Old 03-05-2013, 11:04 PM
on mine i had too set input as /dev/dsp only way it would work thanks for the help
  #48 (permalink)
Old 03-06-2013, 1:07 PM
only thing now is cleaning up the audio its sounding gragged on some channels dunno if its cause of the system or its on my side but its doing good on ubuntua 10.04 so far
