Go Back   The RadioReference.com Forums > Site Administration Forums > Live Audio Feed Administration
Live Audio Feed Administration Administration topics for live audio broadcasting on RadioReference.com. This forum is for feed providers to get support.
Old 11-29-2012, 10:23 PM
KD2DLL's Avatar
Default Looking at setting up a second or third feed
So I am considering setting up a second and possibly third live feed. I want to use the same laptop for them if possible. I only have one mic port in it. I have looked at this however I can't use it because I am not sure if its possible to hook a PCI to a laptop, unless there is some kind of adapter. Is there something similar to this device that is USB or somthing that I could use on my laptop? Any suggestions? Thank you.
Alex Kaczor--- feed@kaczortech.com
Check out my new ham website kd2dll.com
With a scanning forum as well! forums.kd2dll.com
Old 11-29-2012, 10:41 PM
Send a message via AIM to Rob_K
I had a similar problem. I use a thin client so only a mic in port. I had mixed results with the $1 USB sound cards from eBay.
I bought this: Newegg.com - ENCORE ENMAB-8CM 7.1 Channel USB Audio Box
I split the line in (left and right) on it and that serves 2 feeds. I use the mic in on the thin client for #3.
I think it works great. If you want to take a listen, try my Hamden County FD feed. Scanner is a BCT15x.
Old 11-29-2012, 10:44 PM
KD2DLL's Avatar
Correct me if im wrong, but I can use the mic port build into the laptop for feed one, and use the ones in that device for feeds 2 and 3?
Old 11-29-2012, 10:56 PM
Yes. That is exactly what I do.
Feed 1 built in mic port
(I use the radio shack cable in the wiki to take a single stero port to 2 mono)
Feed 2 left channel of line in
Feed 3 right channel of line in
Might even be able to do a fourth if the box has a mic port too. I can't remember if it does or not.
Edit:
I see it has two mic ports. I never tried them. Looks like that one box could do 4 feeds itself!
Old 11-30-2012, 9:46 AM
I use Linux/Darkice to do my streamings. I use an old wyse termianl VX0 I picked up on ebay for $25 and the OS is installed on a 2GB flash drive. For audio input I use an iMic made by griffin I also got from ebay for $8. With alsa you can then use the dsnoop plugin and split the stereo input in to 2 feeds and run 2 instances of darkice with different configuration files. Just google "Darkice split stereo input" there is a google code post with all the info.
If you can boot your laptop from an USB flash drive, I don't see why you couldn't do something like I am doing. Mic inputs on computers are made for electret mics (there is a phantom voltage to power mics of about 5 to 8 or so volts). This causes all sort of hissing and humming noises and what not if you are connecting scanners direct without and impedance matching / isolation circuit in-between.
I imagine you could add more iMics or similar devices to increase the amount of feeds. each time adding 2 feeds or more. You can listen to my feeds at TRYON Amateur Radio Club K2JJI - RACES Drill – Tuesday at 7pm EST | On air: -146.70Mhz PL:100Hz | EchoLink: 510372 | Fulton County NY
Old 11-30-2012, 12:02 PM
I second the recommendation for the USB iMic by Griffin. I've been using it on a Thin Client running two feeds in stereo.
Doug
Old 11-30-2012, 4:19 PM
If cost is an issue for you, try this: Syba SD-CM-UAUD USB Stereo Audio Adapter, C-Media Chipset, RoHS
I have two hooked up to my laptop, been using them for over two months with no issues.
