Go Back   The RadioReference.com Forums > Site Administration Forums > Live Audio Feed Administration
Live Audio Feed Administration Administration topics for live audio broadcasting on RadioReference.com. This forum is for feed providers to get support.
Old 01-12-2013, 3:03 AM
Default Please help ???
I'm Trying to brodcast Brunswick Maine Pd and ambulance and fire but i followed all the instructions and im using scaner cast rr edtion program but it only comes out as static.I have a 3.5 mm hooked to the laptop windows 7 output in mic any help would be great thanks.?
Old 01-12-2013, 3:36 AM
W8RMH's Avatar
Hard to trouble shoot without details or being there.
Try the LINE in instead of MIC in. What scanner are you using? It is best to use RECORD out if your scanner has it.
If you only have a MIC Input:
Open the mixer software on your computer
Go to Recording properties
Look in Advanced Settings for a check box labeled "Microphone boost" or "20dB boost" or similar
Make sure that the boost check box is cleared since you do not want to amplify the strong audio from the scanner any more than it already is!
Have you actually connected to RR and sending audio? Is the "static" heard from listening to the feed, your computer, your scanner?
Make sure nothing else is using the same port.
Have you read Setting up your Broadcasting Station
BCD396XT - BCT15X (Feeder) - BCT15 - Bearcat IV - Yaesu FT60R
Columbus Police Citywide Dispatch
Old 01-12-2013, 9:22 PM
Ok mybe im just being dumb i have a raido shack pro 97 scanner and after looking at it mybe it just has a input only ????
Old 01-13-2013, 2:19 PM
Send a message via AIM to 04Z1V6 Send a message via Yahoo to 04Z1V6
Your scanner has earphone output that can be plugged into a computer sound card what computer are you using and what cable. Maybe this will help, look at the link. Setting up your Broadcasting Station - The RadioReference Wiki
Pro-2096
Pro-106
(3)Pro-197
BCD396XT
Old 01-19-2013, 2:13 AM
Ok I have A toshiba satalite L505-ES5018 laptop and I read the forum you posted do I just need a mono cable to stero that I can get at Raido shack I have a standerd auido cable 3.5 right now that would like plug a mp3 player to a ipod not sure any ideas? Ohh and I called raido shack and he was like well thats prob. illegale he was no help at all. thanks for your help. Although they brodcast other towns here so thats kinda funny lol.
Old 01-27-2013, 5:19 PM
Ok so i tryed the mono cable adaptor to the laptop still nothing please help any suggestions? Should i try mono on both ends or will this laptop not soppurt it? It's windows 7 ????
