Originally Posted by spectr17
spectr17, you are barking up the wrong tree.
First of all, you have made several posts here promoting your own feed. No other feeds that cover the mountain communities have appeared in your posts.
The "Other feed" that you keep referring to, has over 3000 listeners in prime-time while your feed, has about 300. Do I sense "feed-envy" here?
Most of the critical SWAT-type comms have been happening on the Sheriff's PRIMARY channel. The normal traffic that usually has been heard on the primary channel, has been moved to 8-TAC-2. This means that YOU as well as the other provider are rebroadcasting traffic that would normally be heard on a TACTICAL channel. It's like the pot calling the kettle black.
You might want to re-evaluate your own feed. It has lots of white noise and distortion, and you cover so many systems/frequencies, that most listeners go somewhere else to separate the chaff from the traffic that they are interested in. Finding a "key audience" and coverage area that is previously unserved is the key to success here on RR.
I wish you luck in the future.
