Go Back   The RadioReference.com Forums > Site Administration Forums > Live Audio Feed Administration
Live Audio Feed Administration Administration topics for live audio broadcasting on RadioReference.com. This forum is for feed providers to get support.
Old 03-09-2013, 7:40 AM
Question Stereo Feed Question
I am attempting to run a stereo feed using RR ScannerCast on Windows 7. I have set up my broadcast station exactly as shown on the schematic at:
Setting up your Broadcasting Station - The RadioReference Wiki
When listening to the audio on the speakers of the broadcast computer, everything appears as desired: "Scanner #1" audio is only heard from the left speaker, and "Scanner #2" audio is only heard from the right speaker. The Peak Level Meter also confirms that the left and right channels are operating independently. However, when I listen to the feed on Broadcastify, the left speaker has audio from both "Scanner #1" and "Scanner #2". The right speaker is the same (audio is heard from both scanners).
I have selected "Stereo" under the Advanced Tab on ScannerCast. I am assuming that there must be another setting on the computer that needs to be adjusted.
Is anyone successfully running a stereo feed with RR ScannerCast on Windows 7? And if so, can you please let me know what corrections I need to make. Your assistance is greatly appreciated!
Old 03-09-2013, 10:53 AM
Send a message via AIM to 04Z1V6 Send a message via Yahoo to 04Z1V6
I run a stereo feed. What player are you listening to the feed with not all players have a right and left channel. If I were you I wood use Proscan's "Radio Feed". I will listen in and see if it is broadcasting both right and left. here is the link. ProScan
Pro-2096
Pro-106
(3)Pro-197
BCD396XT
Old 03-09-2013, 11:02 AM
Ok, it is running in stereo on both feeds what kind of cable are you using? I had a problem with using the correct cable.
Pro-2096
Pro-106
(3)Pro-197
BCD396XT
Old 03-09-2013, 11:57 AM
Smile
Thank you for responding. However, I know that the cables and connections are correct because the speakers on the broadcast computer are playing the audio correctly ("Scanner #1" on the left speaker, and "Scanner #2" on the right speaker). The Peak Level Meter also shows this. The problem occurs after this point.
Old 03-09-2013, 1:45 PM
Try this, go in to the speaker and headphone settings. Click on your speaker Icon on the tool bar on the bottom when that pops up then click on the speaker above the volume slider that should open a window that has controls go to enhancements and make sure you disable them then go to levels and make sure mono mix has a red circle with a line through it, if it does not click on it to disable mono mix. Shut down and restart. I hope this will work.
Pro-2096
Pro-106
(3)Pro-197
BCD396XT
Old 03-09-2013, 2:24 PM
I will try this as soon as I get home. Thank you.
Old 03-09-2013, 3:19 PM
richtidd's Avatar
Live Audio Administrator
Helping via email.
Richard Tidd
Broadcastify.com
richtidd@broadcastify.com
My online scanners:
SMCo, Tuolumne Co
Old 03-10-2013, 1:26 PM
Smile
Thank you 04Z1V6 and Rich Tidd. Your assitance is greatly appreciated! Rich stated that the RR version of ScannerCast currently has a glitch that prevents stereo feeds from performing properly. He too suggested that I consider running RadioFeed. I plan to make the switch tomorrow.
Thanks again.
