Hello All,
I wanted to see if anyone else has had issues with static on their feed using while using Nicecast. My feed is relatively new and when it first went online it sounded great. After being online a couple of days I noticed a lot of static on the feed. When I finally got home to check it, I found the static was not coming from my scanner, but from the feed itself. After taking my feed offline and rebooting Nicecast, the feed once again is very clear. There are times when I am not home for several days and don't have the ability to reboot Nicecast to fix the problem. Has anyone else had a similar issue with Nicecast or their feed and found a resolution to this problem other than rebooting the broadcast client?
