I've put up a feed about a month ago and things are working great except the audio gets a strange choppy static like sound after random periods of time often between 12 and 48 hrs of uptime i've got all the levels set and audio sounds fantastic normally and have tried both the default software and am using radiofeed now to stream, often restarting the stream will fix it , but sometimes a reboot is required has anyone else seen this prob and can maybe help? I can't constantly monitor the feed and have no way of knowing if the audio is good or not until i listen, please help!
