Go Back   The RadioReference.com Forums > Site Administration Forums > Live Audio Feed Administration
Live Audio Feed Administration Administration topics for live audio broadcasting on Broadcastify.com. This forum is for feed providers to get support.
Old 12-03-2013, 9:55 PM
Default CDN1250 and Uniden scanner for feed HELP NEEDED
I am attempting to use a Motorola DDM1250 to do VHF fire ground and a Uniden BC-796D to do Digital channels. If I plug the CDM directly in to the PC it works perfect, same with the scanner by it self. I use a stereo splitter to connect both radios to the PC. I been using the splitter with two scanners and it works fine. When I plug the CDM in, I get AM radio loud and clear. I tried to ground the radio to the PC with no results. I put in an isolating resistor, it did nothing. I put an in-line volume control, no good. I tried to plug the scanner in with the CDM to see what would happen, I still get the AM radio. Anyone running a feed with this type of configuration??
Copyright ©2000 - 2015, vBulletin Solutions, Inc.
