Hi, I have a feed that for two days now is showing that it is online, but when you try and connect to it, it says that it is offline. I have had to stop and restart ScannerCast both days. What could be causing this?
Are you using the player that pops up on broadcastify???
If so this has been happen to me as well over few days. The feed shows online but when try to play the feed shows an X and player never starts and it's been random off and on my on all my feeds.
I downloaded scanner deluxe for my iphone so when this happens can pull up the app and see that feed is fine and still online. Also might give Radiofeed a try it just as easy to use as scannercast and it has log at bottom of feed that shows when feed is offline or connected unlike scannercast.
