Go Back   The RadioReference.com Forums > Site Administration Forums > Live Audio Feed Administration
Live Audio Feed Administration Administration topics for live audio broadcasting on Broadcastify.com. This forum is for feed providers to get support.
Old 06-06-2014, 3:23 PM
Default Radio Feed 2.8
How do I get the channel names to show on my feed using Radiofeed 2.8?
Old 06-06-2014, 6:07 PM
I guess I should have been clearer of what I am looking for. Does anyone have or can they post a sample of the channel list that RadioFeed uses to supply the channel names?
Thank you,
James
Old 06-06-2014, 8:36 PM
ProScan's Avatar
Thank you,
James
The channel name text tags (and a lot more data to use for text tags) comes from the scanner via the RS-232 port. What kind of scanner are you using to supply the feed? RadioFeed Metadata tab is where the RS-232 setup is. A media player must support metadata. WinAmp supports metadata.
Old 06-06-2014, 9:04 PM
I have a BCT8, it is connected to the rs232, the little lights in the radio feed program are blinking.
I have programmed all the channel names in the radio.
Any help would be greatly appreciated.
Thank you,
James
Old 06-06-2014, 9:29 PM
ProScan's Avatar
Thank you,
James
Blinking lights indicate the scanner is talking to RadioFeed. Enter %C in the Custom Format box. You should see the channel name text tags in the Metadata box.
Old 06-06-2014, 9:34 PM
I have the %C there it just shows the name of my feed, I'm using Scanner Radio Pro to listen and it shows tags from other scanners
James
Old 06-06-2014, 9:48 PM
ProScan's Avatar
James
What does the Metadata box show?
Old 06-06-2014, 9:50 PM
It shows the name of my scanner
Old 06-06-2014, 10:05 PM
If I change to %F it shows the freq, but when I go back to %C it reeverts to the name of the scanner not the channel name.
Old 06-06-2014, 10:30 PM
ProScan's Avatar
I see "154.7400" when it's locked on a frequency. It seems like you want the text tag to show and not the frequency. Do you have text tags programmed in the scanner?
The "Scanning Tehama SO & Corning PD" is from the "Text To Show During Scanning" box
Old 06-06-2014, 10:35 PM
Yea that's what i get if i put &F i get the freq, But when I put in %C all I get is Scanning Tehama SO & Corning PD. I do have the text programmed in the scanner. Just looked again to make sure.
Old 06-06-2014, 10:55 PM
Was just watching the meta data space, when the scanner stops on a channel it goes blank, when the scanner resumes it again shows "Scanning Tehama SO & Corning PD"
Old 06-06-2014, 11:35 PM
ProScan's Avatar
Does the scanner display show the channel name? Try a %S and %G to see if that will show the channel name.
Old 06-06-2014, 11:38 PM
W8RMH's Avatar
The BCT8 does not do alpha tags. All you will be able to display is the frequency and/or talk group.
Home Patrol-II BCD996XT BCD396XT BCT15X BCT15 Bearcat IV
Columbus Police Live Audio
Old 06-07-2014, 11:45 AM
ProScan's Avatar
Thanks for the info W8RMH. %C label removed from the BCT8 next version.
Copyright ©2000 - 2015, vBulletin Solutions, Inc.
