Originally Posted by RRn00b
Sometimes I turn one side down, but I listen to both most of the time so I can hear Port Orchard police and Kitsap county sheriff. Kind of confusing sometimes but no complaints, I really appreciate that you provide this feed!
I've been having trouble yesterday and today with the feed stopping after 5 or 10 minutes. If I reload it, it usually starts again but then stops again. Not sure if it's the feed or something with my computer?
I would start by "resetting" your IP address. To do this, you would reset your modem, depending on model, by either the reset button on the rear of the modem or unplugging it for approximately 10-45 seconds and plugging it back in. I've had problems like that before, and that is what has worked for me. Also, any kind of preventative maintenance you can do on the computer itself (depending if it's a dedicated computer or not) will likely help. If you need more in-depth instructions on resetting your modem, send me a private message with what type of modem and internet connection you have and I'll try and help you out as best I can.
-Shawn
