| Live Audio Listener Support This forum will act as a place for individuals who listen to feeds to provide comments or concerns about specific feeds. All feed providers should monitor this forum for feedback on their feeds. |
02-20-2013, 6:44 AM
PSR-410 and Metadata
I have a GRE PSR-410 scanner for my one feed and I have the USB cable plugged in to it and have my software set for sending Metadata and it shows channels on the ProScan software but it does not appear to be sending the Metadata to RR servers. Any help would be appreciated.
02-20-2013, 7:46 AM
Where do you see the metadata in ProScan or RadioFeed? Do you mean RadioFeed and not ProScan? ProScan doesn't support any GRE/RS models. RadioFeed does however it doesn't support the 410. It may or may not work. You may have to select a scanner type that is similar.
To view metadata on the media player side, use a media player that supports metadata such as WinAmp.
02-20-2013, 11:25 PM
You are correct, it's RadioFeed. I selected PSR-500. I wasn't sure if there was a difference between a 500 and a 410 as far as Metadata interops went.
Can anyone see if my feed is working properly?
Mifflin County Law Enforcement Live Scanner Audio Feed
02-21-2013, 5:40 AM
Metadata shows "Scanning" continuously. Before, you advised that the channel data shows. Where does it show?
02-21-2013, 6:12 AM
Under the Test1 Tab it shows scanner data and shows the channels as it scans.
02-21-2013, 7:05 AM
That's the raw data returned from the scanner. The metadata sent out shows on the Metadata tab. Do you have in the Custom Format box "%C" for channel? It may not wok if the 410 data is in a different format and RadioFeed doesn't support the 410.
02-21-2013, 11:07 PM
Yes I have that in there. Does anyone know if there is going to be an update to support the 410?
02-23-2013, 6:08 AM
410 support can be added. Email me and then I can start it. I will need your help testing 410 support.
02-23-2013, 6:55 AM
DB Admin
I can also help test 310/410 support, Bob. I'll email you as well.
02-23-2013, 8:05 AM
I can help too Bob. Have a 410 sitting here ready for testing. E-mail sent.
02-24-2013, 9:33 AM
Thank you Chauffeur6 and NYRHKY94 for all the help with testing the RadioFeed PSR-410 metadata.
02-24-2013, 12:31 PM
DB Admin
Glad to help.
02-24-2013, 1:05 PM
Me too :-)
02-24-2013, 11:39 PM
email sent as well. lets do this!
