Go Back   The RadioReference.com Forums > Site Administration Forums > Live Audio Listener Support
Live Audio Listener Support This forum will act as a place for individuals who listen to feeds to provide comments or concerns about specific feeds. All feed providers should monitor this forum for feedback on their feeds.
Old 04-28-2013, 5:59 AM
Default Sprint now blocking Broadcastify???
Using "Scanner Radio" app on Android with Sprint I am "unable connect to audio server". Diagnostic mode it tells me: "Problem Detected" "Your carrier is intercepting the app's attempt to connect to Broadcastify.com's audio servers." This only happens when my phone is in 3g (Sprint) mode. When my phone is connected in wi-fi mode (through my router) it works fine.
Anyone else having this issue?
Old 04-28-2013, 7:58 AM
Now this is would be interesting if true.
Old 04-28-2013, 9:39 AM
No problems here...
Old 04-28-2013, 11:29 AM
This came up in another thread recently, along with a noise issue.
The noise issue was resolved, but unsure if the other issue was.
The carrier in that case was Verizon, and appeared to be limited to a single feed.
Are you having problems with one feed in particular, or all feeds?
Old 04-28-2013, 12:56 PM
All feeds. Tried both local and various "top" feeds. When I'm home & want to listen I simply turn on my scanner. It's nice to be able to use the live feeds at work or wherever through my phone. I'll download and try with another phone later tonight and see what happens.
abbadabbado - While you personally may think it's wrong to stream audio, not everyone agrees with you. Including our local FD, which streams it's own audio online and shares the RR/broadcastify link right on their homepage.
Old 04-28-2013, 2:03 PM
KC9NEG's Avatar
I saw this once on Verizon 4G. A cache clear/reboot resolved it.
Old 04-28-2013, 8:07 PM
Live Audio Administrator
Are you running version 3.9.5 or later of "Scanner Radio"? Earlier versions of the app will falsely report that the connection is being intercepted due to a change that was made to one of Broadcastify's servers.
Can you run the app, then select "Diagnostics" from the menu again, and then select "Share" from the menu to send me (the developer of the app) the info? Once you've done so, send an e-mail to me at support@gordonedwards.net letting me know and I'll take a look at what it reports.
Thanks,
Gordon
Copyright ©2000 - 2015, vBulletin Solutions, Inc.
