Go Back   The RadioReference.com Forums > Site Administration Forums > Live Audio Listener Support
Live Audio Listener Support This forum will act as a place for individuals who listen to feeds to provide comments or concerns about specific feeds. All feed providers should monitor this forum for feedback on their feeds.
Old 02-14-2014, 2:59 PM
Question Anyway to balance the feed transmissions
Is there any way to balance the scanner input to the feed so when the feed goes through and is sent out, the audio is equally or close to balance from each transmission? ie: dispatchers and cars from same department or same dispatchers for different departments
Old 02-14-2014, 5:37 PM
n0nhp's Avatar
Until scanner makers make an AGC that actually works, the short answer is no.
The radio techs that set up the different system all seem to have their own set of rules when it comes to deviation. That is what we, the feed providers get off the air and pass on down the wires to the server.
Different scanners will respond differently as well my older 796 does not do as well as the newer 996T but I cannot afford to replace the older scanner that is working just because the audio is not quite as good.
Processing the audio either in the computer or the server would induce "breathing" as the audio goes quiet between transmissions and a pop when the transmissions come up. Very annoying.
Bruce
N0NHP
Tags
audio balance, feed audio
