Go Back   The RadioReference.com Forums > Regional Radio Discussion Forums > Louisiana Radio Discussion Forum
Louisiana Radio Discussion Forum Forum for discussing Radio Information in the State of Louisiana.
Old 06-09-2009, 07:20 PM
Default Conventional P25 - NAC
Is anyone aware of any conventional P25 systems using NAC codes in the Baton Rouge area? I want to test ID Tracker II NAC detection.
David M. Hitchner - K5DMH
Baton Rouge, LA
Baton Rouge Area Scanning: http://bellsouthpwp.net/k/d/kd5eis
ID Tracker/ID Tracker II: http://bellsouthpwp.net/k/d/kd5eis/i.../IDTracker.htm
Old 06-09-2009, 08:42 PM
You could just program these freqs as conventional. and the NAC would show up each time.
(note: all the NAC's will be the same. Since it's a trunked system)
Louisiana Wireless Information Network (LWIN)
http://www.radioreference.com/apps/db/?sid=4347
There must be some P25 freqs in the fed band 162-174 in your area.
Old 06-10-2009, 05:50 PM
Scanner Frequencies: Louisiana Wireless Information Network (LWIN) Trunking System, Statewide, Louisiana
Thank. I will give it a try. I was not aware that the trunked systems transmitted an NAC.
Baton Rouge, LA
Old 06-10-2009, 09:21 PM
That worked. Each site gave a different NAC so that was enough to do what I wanted.
Baton Rouge, LA
Similar Threads
Jersey City Trunking Up CqDx New Jersey Radio Discussion Forum 53 05-15-2009 06:51 AM
Auto, NFM, or FM for your P25 chnnels? SOFA_KING Federal Monitoring Forum 24 04-29-2009 07:43 AM
PSR-500 and conventional P25 scanfan03 GRE Scanners 1 10-07-2008 01:55 AM
Database P25 conventional report question mancow System-wide Administration 2 08-05-2008 09:50 AM
Common Fed Freqs mike_s104 Federal Monitoring Forum 63 04-23-2007 11:39 AM
