Is this the thread you were looking for?
May have found Barksdale AFB
A couple of points on the band plan situation:
- If it is set up as an implicit system, the Unidens should be able to display the band plan after a few minutes of monitoring the CCh.
- If it is set up as an explicit system, it will take some research, preferably with a decoding software package to figure this out.
In either case, once someone gets the band plan, they should submit it so that it can be added as a note for those scanners that need to have the band plan entered.
