St. Tammany, Washington, Tangipahoa Parish Sheriff's Offices
SCPD
QRT
Virginia
Does anyone of the forum know what the above listed Parish Sheriff's Office unit identifiers are? If you don't know what unit identifiers mean they are how a unit calls there dispatch. Thanks much!
INDY72
Indianapolis, IN
Tangi used to use district numbering. Example: 529 was district 5 unit 29.
INDY72
Indianapolis, IN
Example of actual Tangi SO comms back a couple of years ago:
529, Amite. Amite, go ahead 529.... etc...
SCPD
QRT
Virginia
Thanks for the info milf. Do you know about St Tammany & Washington SO's and how they call out? And do you know how Tangi calls out currently?
INDY72
Indianapolis, IN
Wash Washington was similar... Tangi you CAN NOT hear as they use an ProVoice Digital EDACS which NO SCANNER can listen to. I have not been close to SW MS and NE LA in a couple of years... So they might still be the same.. Youll have to monitor and see. :)
SCPD
QRT
Virginia
Thanks milf. Hey milf would you happen to know what frequency Marion County Mississippi Sheriff's Department runs off of?
radiogirl
Actually, it is St Tammany that is using ProVoice, not Tangi. Tangi is wide open but is using a lot of narrow band freq's now. I know you meant to say St. Tammany in your post.
INDY72
Indianapolis, IN
OOPPS yep sorry am tired.. LOL Tangi is still conventional analog though has plans to go trunked. And I pm'ed the MCSO stuff
AC0RV
Park Hills, MO
Washington Parish SO using WP #### for the units or at least they.
Since I have away for a while I can not really say about the rest of the Public Safety Users for the Parish.
