Go Back   The RadioReference.com Forums > Commercial and Professional Radio > LTR Trunking
LTR Trunking General discussion of LTR, LTR Multi-Net, and Passport Systems
Old 07-31-2008, 10:29 AM
Cool Programing 1 frequency LTR system
I live in Ulster County in New York State. We have two LTR systems that have only one frequency in them. I know that you have to put LTR and ED trunk systems in LCN order. But here is my question, if there is only one frequency, could you get around this and put both systems in one bank and still have it trunk the LTR systems? Thanks for your help..........Ray
Old 07-31-2008, 11:20 AM
alphabravo1's Avatar
Yes... however depends on the scanner. and the LCN position or logical channel number.
I have two separate systems in one bank, (system) one is UHF and one is 800 MHz and it works fine. one is LCN one and the other is LCN four
That is the Pro-2055/Pro-164
And I did the same with my BCD396 and they both work,
but I don't monitor them often enough to see if it works well. I've not noticed a problem.
But both scanners work.
Old 07-31-2008, 12:23 PM
I forgot to say that they are both UHF LTR systems........Ray
Old 07-31-2008, 12:45 PM
JGP's Avatar
JGP JGP is offline
The LTR systems can be VHF or UHF or 800. The systems must not use the same LCN order, or it will not work. You can use all twenty LCN slots if you want for twenty one- frequency systems. It will work in GRE 500/600, Uniden 396/996, and bank scanners. You just can't have two or more frequencies using the same LCN order.
Old 07-31-2008, 01:34 PM
captclint's Avatar
If there really is only one channel for each system(rather unusual). then you can program them as conventional and put them anywhere. You would miss the TGID alpha display, so this is just another suggestion in case you don't know the LCN. I suspect there are other channels, so if you seem to be missing parts of converstations, start looking for the missing channels.
Regards,
Clint Chamberlin
Luzerne County, PA
Old 07-31-2008, 01:56 PM
cg cg is offline
the only other issue would be identical talkgroup IDs. If there were duplicated TG IDs, they would be recognized as only 1 TG.
chris
Old 07-31-2008, 02:54 PM
it's really one frequency for each LTR system ---------
1- Town of Crawford-CH-01-453.8125-----T/G---0-01-111
2- Town of Shawangunk-CH-01-453.7375----T/G--0-01-110
If you don't program them in LTR mode, they will scan but you get this clicking like sound which will drive you nuts after a while. I use my pro-2055 and pro-97 most of the time......Ray
Old 07-31-2008, 08:01 PM
tennesseefreq's Avatar
Have you tried the other frequencies listed on the licenses to see if they may be LTR also?
WQCP435 - CRAWFORD, TOWN OF
453.3625
453.5375
453.8125
WNKR311 - SHAWANGUNK, TOWN OF
453.7375
460.0250
Old 07-31-2008, 08:53 PM
I have tried 453.3625 and 453.5375 never head a thing for Crawford and for Shawangunk 460.025 was their frequency when they had a conventional set up. Then like Crawford switched to a ED trunking system for a few years and had to many problems with it, so they went to a LTR set up....Ray
Old 07-31-2008, 08:59 PM
Ltrdump indicates that Shawangunk is a two channel system with LCN's 1 and 3. The traffic level is probably low enough that LCN 3 almost never activates. Crawford is not receivable here.
Since Crawford and Shawangunk both use LCN 1, there is no way to put both systems in the same bank if you want LTR tracking (with the radios mentioned in this thread).
Similar Threads
Dallas police, firefighters frustrated with automated dispatch system Firetxmi Texas Radio Discussion Forum 13 03-13-2008 06:49 AM
Yet another LTR mapping system post NW0U LTR Trunking 7 03-07-2008 09:44 AM
Pro 97 and LTR system KrazyKevin Radio Shack Scanners 8 04-05-2007 05:54 PM
Questions About Programing a Trunking System... _DeS_ Trunking Forum 10 07-09-2006 07:17 PM
Tipton eyes switch to new radio system jwheatley Indiana Radio Discussion Forum 0 03-20-2006 07:19 AM
