Originally Posted by altec
I did a fcc search and programed all the trunked system freqs as conventional to see if any are active. Most are not and can't see any signs of it being a trunked system. Occasionally when activity does occur it displays a dpl code. So I assume there are no LTR systems currently setup in my area.
Not necessarily. As Dave said, quite often, a system of repeaters will have 1-2 out of 6-10 total repeaters on conventional mode, usually with PL/DPL and the others LTR. However, you have you examined all the systems in your area, and you did not hear the "spitting" sound every 5-10sec...right? This sound is not guaranteed to be present on an LTR freq, but it is fairly common. I find that systems with this sound can remain inactive for quite a while before they go active LTR.
