| LTR Trunking General discussion of LTR, LTR Multi-Net, and Passport Systems |
09-20-2008, 01:20 AM
Learning LCN
Is there any of the high end scanners that can learn the correct LCN's?
Uniden BCD996XT | Radio Shack Pro197 | Radio Shack Pro-2055 | Uniden BCT-15 - Mobile | Radio Shack Pro-92
Software: Win500, Win97, Win92, Proscan, Freescan & I.D. Tracker
09-20-2008, 08:37 AM
Yes! The GRE PSR-500 and PSR-600 have an automatic repeater placement feature for LTR systems.
David T. Stark, NF2G
Educator - Criminal Justice, Sociology
NF2G's Forensic Scannist Pages http://nf2g.com/scannist
Don't run from the police. Motorola always beats Mopar!
09-20-2008, 04:49 PM
Thanks, I have my heart set on a PR-600
09-22-2008, 04:41 PM
PRO-92 doesn't require the channels to be in LCN order. It's about 50-60$ on Ebay.
Ø
Motorola Systems Saber Net
0249AF6AB3915CD2
09-26-2008, 01:36 AM
Or you could use your brain and about 15 minutes of logic. But its probably easier to just go out and burn-up some money on some old scanner on Ebay....
If you wish to make an apple pie from scratch you must first invent the Universe. - Sagan
09-30-2008, 09:21 PM
Low end Scanners will tell you LTR LCN's, as posted above and in Quotes, Takes only a few minutes, well maybe 30 minutes on a Bigger system to figure out the order. If frequency 453.0125 displays ID's such as 0-03-012 there is a good chance 453.0125 is supposed to be in LCN Ch-3.
KF5CXT/WQIW237
Trenton, Texas USA
V-8000 - FT2800M - PSR600 - PRO106 - PRO160 - BC898T - IC-F221 - IC-F70D
09-30-2008, 09:32 PM
I've noticed on some of the systems around here that two or three freqs will show the same home channel such as R02 or R03. You just have to figure out which TG that you want to hear.
10-06-2008, 06:35 AM
Blocking Unwanted TG's
Wrong thread
