How much performance you lose depends on what you are comparing it too. The basic comparison is usually to a 1/4 wave antenna. They usually claim similar performance to a 1/4 wave, but you'll likely see less. These are physically shorter than a 1/4 wave, so they won't work as well. The more "low profile" they are, the less well they will work. There isn't any magic that goes into antennas, it's all dictated by physics.
If you are really on the edge of the system coverage, this antenna is probably not a good choice. They are a "compromise" antenna. You are trading some performance for lower profile. A 1/4 wave antenna is going to be really cheap, like $10. They blend in well, with most vehicles. I'd recommend starting with the $10 quarter wave antenna and see how it works. If the performance is satisfactory, then you could try the lower profile antenna. If the performance of the 1/4 wave isn't up to what you need, then you'll know it's not a good idea. Either way, you'll only be out $10.
