| LTR Trunking General discussion of LTR, LTR Multi-Net, and Passport Systems |
08-28-2004, 08:07 PM
Simpler Data Dicer
Hello,
My LTR exploits were on the back burner due to a death in the immediate family. I did listen to the DNC comms and have found some interesting Passport LTR stuff on 217 and 220 MHz. The problem is my LTR-enabled BC780 scanner can not do the 6.25 KHz steps needed for 220 MHz. Last weekend I dug out my protoboard, some components, and my oscilloscope. I was going to build a LTR slicer for my AOR 8600 but I also wanted to get an idea of how well Bessel filters did (2 poles vs 4 poles vs 6 poles, etc).
I found TI has a nice (and free) Windows program for designing filters called FilterPro. To start off I designed a 2 pole 300 Hz Bessel filter using some on-hand components. As expected it did filter but any strong voice buried the LTR data. I got a surprise when I tried a 4 pole 300 Hz Bessel filter. It filtered alot of the voice out. I decided to see how good a 4 pole filter could do and started designing a complete circuit. I discovered another type of filter supported by FilterPro, the linear phase filter. A 4 pole linear phase filter is even better than a 4 pole Bessel filter and still had the group delay response meeded! The reason I used 300 Hz as the corner frequency is I heard that any filtering should pass at least two times the data rate.
Most of the LTR slicer circuits are complex and are designed to be bulletproof. I get the impression that some people are running the LTRDump/LTRTrunk programs with a regular non-filtered slicer because the filtered designs are complex. I stumbled on a simplified design that will work 90 percent plus of the time. I can not say it works 100 percent because it may fail to work on the "Deep Bass Singers" talkgroup where the radios are putting out a very compressed 5 KHz deviation. Using a 4 pole filter allows a circuit design using one Quad Op Amp IC so it can be RS-232 powered.
I remember from my previous life as a 2-way tech that PL tones were set at .75 KHz deviation. If I assume that LTR data is the same amount it means that 5 KHz voice deviation is 6-2/3 times stronger or if I convert to a voltage ratio, 16.5 DB. This means any filter has to reduce the voice frequencies by at least 16.5 DB. You really need to get the voice lower by a couple of more db before you can expect a solid decode. Because the input is assumed to be limited to 5 KHz deviation improving the filter response beyond -20 db (like to -28 db) gains very little. I also suspect that radios tend to hit 5 KNz mainly on voice peaks. There are periods of lower deviation when people take a breath, etc. So a 4 pole filter is good enough most of the time. Also the LTRDump/LTRTrunk program "oversamples" the data bit so a momentary voice peak getting through may not affect decoding.
I could not make this a "Radio Shack" type project because I could not find component values using FilterPro that matched the token values that Radio Shack offers. Another factor is the giant size of the capacitors at Radio Shack. Filters need components with small tolerances and temperature stability so a .1 uf Z5U ceramic capacitor that will vary from .05 to .12 uf will not work very well. Fortunely you can get good resistors and caps easily from Mouser Electronics. AVX makes 63 volt boxed film capacitors that are not very big and have a .2 inch lead spacing. I used the AVX 5% tolerance capacitors and Vishay/Dale 1% tolerance 1/8 watt resistors. I can not fit the circuit into a 9 pin connector shell but it can fit in a small box. Maybe someone skilled with surface mount can make it fit in a 9 pin connector shell.
I do not use a capacitor on the input. I do recommend a resistor in the radio between the discriminator tap and the connector you use. The buffer eliminates the effects of the radio on the filter. Since I also use MTrunk and ETrunk I have a switch to eliminate the filter. The filter is a MFB type to lessen the effect of component tolerances on the filter parameters. By having the 1.0 uf capacitor and the switch at the comparator input the data polarity can easily be inverted.
I hope people find this circuit useful. It is more difficult to build than a Motorola slicer but easier than the other LTR slicers. I am about ready to go from the breadboard to a soldered version in a small box for "Field Testing".
73 Eric
08-29-2004, 11:16 AM
Nice design - I especially like the choice of op amp
The cutoff can be set to 150 Hz with no problem and the voice rejection will be greatly improved. The attached file shows the results of a computer simulation of the circuit. Doubling all the resistors changes the cutoff to 150 Hz. Note that at 500 Hz the rejection improves from -9.6 dB to -32.3 dB. Phase remains approximately linear and the time delay rises but that is of no consequence. LTR subaudible data is transmitted at 1 kHz deviation according to a service manual from EF Johnson. The data is filtered at the transmitter so receiver response above 150 Hz is not required.
For those still using a capacitor to couple the discriminator output, add two resistors to the circuit (10K and 1 Meg) as shown in the attached schematic. This establishes a DC reference for the op amp and provides real isolation between the slicer and radio.
The better approach is to use a resistor in the radio as you did. If it is 10K, then placing a .001 uF capacitor from the jack on the radio to ground will filter the discriminator output for Mot and EDACS. The resulting single pole 16 kHz rolloff will not interfere with decoding but will suppress high frequency noise that the MC3161 spews.
Except for the switches, this circuit could be made to fit in a 9 pin D-shell header. All the required surface mounted parts are available.
pro92b
08-29-2004, 12:17 PM
I just need a little clarification.
Do I understand correctly that this new circuit would be switched into and out of a "normal" HamComm-style slicer connection to add LTR capability?
73 de Dave, NF2G
08-29-2004, 01:19 PM
Yes, the upper switch allows you to bypass the LTR filter for Mot/EDACS decoding.
I forgot to mention that all the capacitors in the circuit are shown as non-polarized (not electrolytic types). This is necessary if the discriminator is coupled through a capacitor. For resistor coupling polarized capacitors can be used although they are far less accurate than the nonpolar types.
09-10-2004, 05:45 PM
Great circuit ...
I finished one and ran it with Motorola, EDACS, LTR, Passport, and Multinet systems. No problems noted. The previously saved systems seem to pop up very fast.
I did see a number of transmissions that are missed by the LTRTrunk on Multinet when I had a chance to be in the area of a Waterbury CT radio that was busy. I did a LTR dump with the new decoder and haven't had a chance to look through it yet.
Also, I built it in a small project box and added a second DB-9 connector with the pins for the second radio passing through.This way the monitoring radio can be added without a special cable.
chris gordon
granby ct
09-12-2004, 10:55 PM
Here in Kansas City Passport has taken over.I have read all through the forum posts about the programs but am still getting nowhere.I am a novice at building circuits but after having luck building a simple 2 level slicer I was feeling confident that I could make the one above.
So far I have made 2, and on both of them work just great for Moto and EDACS ( actually much better than the current one I use) but when I run the filter and run LTRtrunk or LTRdump I get no info at all so I fear Im building the filter part incorrectly or tapping it wrong or running the program incorrectly.In any case Im sure its on my end. The I have checked the circuit over and over and I cant see and screwups on routing.
I tapped point A on my 780, didnt have a 1k resistor so I used a 3.92K I had laying around (left over from the filter). RS-232 Output I put to CTS PIN6 on the DB-9 on the slicer. All the freqs were put in a bank and programed as LTR and scanned in trunked mode. I was unclear if the L should be showing or not so I tried it both ways with no luck.
When I run LTRdump it goes to the screen that says "If program just sits here press any key - and check settings". If I toggle the polarity switch on the slicer it goes into the program but nothing else ever happens. If I run it with it in nonfiltered mode, the program starts but there is nothing happening when I get LTR comms.
When I run LTRtrunk, it loads but nothing else happens. Seems like i can get it to find the right pin (CTS) but there is no signal during comms and nothing ever happens.
First question I guess is, Is there a way to verify my slicer ( maily the filter part) is working properly aside from the programs working?
Is there any special settings for the software I need to make?
And last , since Im not great at interpreting diagrams were all the intersections on the schematic connections? I assumed they were but wasnt positive.
Any help would be greatly appriciated
Gregg in Kansas City
09-13-2004, 05:26 AM
ksmoscanner,
I think your tap is incorrect. If you are talking about point 'A' I think this would be slicer point A - ie. the internal slicer of the 780. For an external slicer you want the discriminator output of which there is only one. Let us know if you need more help.
Opus
09-13-2004, 08:16 AM
My slicer is working off all my scanners and also off a Motorola Maxtrac. Both are using a standard discriminator tap for moto/edacs and the same point for LTR. I have the DATA OUTPUT on pin 8 (CTS). I ran the SLICER program and that shows active pin as CTS.
chris gordon
granby ct
09-13-2004, 04:06 PM
Thanks for the info, I retapped the 780 @ LND8 with a 1k resistor and no cap and ran slicer and the interupts were very very low when run though the filter showing CTS as the active pin but just fine when not so I am guessing the filter is part of my problem. I plan on building another without the toggle so I can use it for LTR only. My PC is putting out -19v from the connector to ground and I have the +19v to the Vcc and the -19v to the Vee. Turned out I had the output to pin 8 and not pin 6 as I thought so am ok there.
I have included a crude diagram on how I wired the slicer from the chip.. I did not include the power supply portion as I think it is ok. Also I omited the 1st toggle so I can just make it LTR only. Did I read it right?
All resistors were 1/8W 1% as specified.
All Caps were 63v 5% Film with the exception of one which is 50v 5% film.
MC33174N was the IC used.
On a side note, can I run LTRtrunk and ltrdump on a tapped 2006 or BC895? I have working taps on both these units.
Thanks Gregg in KC
09-13-2004, 07:59 PM
.015uF should be .15uF. .012 and 3.92K should connect to output 3. Double all resistor values for 150 Hz cutoff. Slicer will show around 150 interrupts per second. No serial port I know of can put out 19 volts. Usual output is around 10 volts, sometimes less. I use LTRtrunk from a tapped PRO-2006 and it works well.
09-14-2004, 03:53 AM
Thanks for the help, I built another one with the changes but I didnt have parts to double the resistor values. The new one has 110 interrupts (which is 108 more than the last one) and shows signs of life. LTRdump has very sporadic logs on a very active LTR freq with a single user with an occasional embedded pattern noted. Sooner or later ill get it right.
Again thanks for the help.
Gregg / KC
09-15-2004, 09:53 PM
That looks complicated.
Radio shack sales man.
Waldo325mvfd
jarhead325mvfd
The weatherman
~~ "It's God's Job to Forgive Osama" ~~
"It's Our Job to Arrange the Meeting"
United States Marine Corps
USMC
09-16-2004, 07:05 PM
Ok I think I got it working. I ran ltrdump and this is what came back for a single freq. Since Im new to this I cant tell if the info is correct or just junk or both but Im making progress getting it setup.
Gregg in KC
09-16-2004, 08:31 PM
There is a lot of good information about the LTRunk and LDump stuff in the archives (look in trunker/etrunker/t4win decoders threads).
I am not great at reading the dump files but you appear to have some good info in the file. I assume you know that the frequencies are in the LCN info (LCN*.0125 + 450.0000 fives you the freq). I saw 7 or 8 valid freqs referenced. If you still cannot get the LTRTrunk to run, be sure you are trying both normal and invert.
chris gordon
granby ct
09-16-2004, 09:44 PM
Gregg in KC
Hello,
If you were listening to an active LTR voice transmission then the decode is not good.
If it was the idle bursts then it may be okay as not all data burst are decoded good.
With a good decode on regular LTR voice comms you should get about 7 or 8 frames per second. Passport and Multinet is about 4 frames per second.
73 Eric
09-16-2004, 11:21 PM
Thanks for the replies... it was indeed a voice channel. I do not get anything at all on the bursts.
Oh well I tried..... and will try again later.
Gregg in KC
12-08-2004, 09:41 PM
After waiting 2 months to try again at building a slicer I decided to try the first slicer on another older PC and it appears it is working. Unsure why it doesnt work on the new PC...Anyhow heres what im now getting on a local freq....
From LTR Trunk 4
Mixed Licensees
MAP=55555555
OPTIONS=nVDf
PLAN=F
DESCR=LTR Passport
THRESHOLD=50
DISPOSITION=fulxsr
v451.3000,68,ffff,98
v452.5000,c8,ffff,8a
v454.0625,145,ffff,89
v454.0875,147,ffff,6a
v454.3750,15e,ffff,91
v454.4000,160,ffff,84
c v454.4250,162,ffff,b66
v454.5750,16e,ffff,3e
v454.6000,170,ffff,51
v461.2000,380,ffff,83
v461.4000,390,ffff,78
v461.8250,3b2,ffff,9b
v462.0500,3c4,ffff,68
v462.4000,3e0,ffff,7a
v462.5250,3ea,ffff,7b
v464.0000,460,ffff,84
Thu May 13 18:48:01 2004 Dumper Version 10-Nov-2004
058857ef183c4e9 Passport DCC:0 LCN 964 Free LCN 354 Active(00) -> 10-64995
058857ef1846025 Passport DCC:0 LCN 1120 Free LCN 354 Active(00) -> 10-64995
1ffc57ef189627d Passport DCC:0 LCN 354 Unkey -> 10-64995
Thu May 13 18:48:23 2004 Dumper Version 10-Nov-2004
08521572 *revcrc Area:0 Ch 10 Free Ch 4 Active -> User: 0-5-33
Thu May 13 18:48:27 2004 Dumper Version 10-Nov-2004
058857ef3016e8d Passport DCC:0 LCN 366 Free LCN 354 Active(00) -> 10-64998
058857ef3039041 Passport DCC:0 LCN 912 Free LCN 354 Active(00) -> 10-64998
058857ef3016070 Passport DCC:0 LCN 352 Free LCN 354 Active(00) -> 10-64998
058857ef301476b Passport DCC:0 LCN 327 Free LCN 354 Active(00) -> 10-64998
058857ef301454e Passport DCC:0 LCN 325 Free LCN 354 Active(00) -> 10-64998
Thu May 13 18:48:28 2004 Dumper Version 10-Nov-2004
0588501fc315e01 Passport DCC:0 LCN 350 Free LCN 354 Radio ID -> 10-1016
058857ef303b200 Passport DCC:0 LCN 946 Free LCN 354 Active(00) -> 10-64998
058857ef30068f7 Passport DCC:0 LCN 104 Free LCN 354 Active(00) -> 10-64998
058857ef300c810 Passport DCC:0 LCN 200 Free LCN 354 Active(00) -> 10-64998
Thu May 13 18:48:29 2004 Dumper Version 10-Nov-2004
057857eae03802d Passport DCC:0 LCN 896 Free LCN 350 Active(00) -> 10-64860
057857eae03e081 Passport DCC:0 LCN 992 Free LCN 350 Active(00) -> 10-64860
057857eae03ea35 Passport DCC:0 LCN 1002 Free LCN 350 Active(00) -> 10-64860
058857ef303c4f2 Passport DCC:0 LCN 964 Free LCN 354 Active(00) -> 10-64998
Thu May 13 18:48:30 2004 Dumper Version 10-Nov-2004
1ffc57ef3096266 Passport DCC:0 LCN 354 Unkey -> 10-64998
05885061ddc6002 Passport *badcrc (0023)
05885020dd96eb1 Passport DCC:0 LCN 366 Free LCN 354 Register -> 10-1051
05885020ddb907d Passport DCC:0 LCN 912 Free LCN 354 Register -> 10-1051
Thu May 13 18:48:31 2004 Dumper Version 10-Nov-2004
05885021d8b60e5 Passport *badcrc (0016)
05885020d8947fe Passport DCC:0 LCN 327 Free LCN 354 ACK -> 10-1051
05885020d8b45db Passport *badpar (002c)
Thu May 13 18:48:32 2004 Dumper Version 10-Nov-2004
05885061d8bb295 Passport *badcrc (0023)
0534d7ef300c85d Passport *badcrc (003e)
051457ef303803e Passport DCC:0 LCN 896 Free LCN 325 Active(00) -> 10-64998
Thu May 13 18:48:33 2004 Dumper Version 10-Nov-2004
0534d7ef303e092 Passport *badcrc (003e)
051457ef303c4bf Passport DCC:0 LCN 964 Free LCN 325 Active(00) -> 10-64998
051457ef3046073 Passport DCC:0 LCN 1120 Free LCN 325 Active(00) -> 10-64998
Thu May 13 18:48:34 2004 Dumper Version 10-Nov-2004
0f8057eae016ebe Passport DCC:0 LCN 366 Free LCN 992 Active(00) -> 10-64860
05885020d8b90d4 Passport DCC:0 LCN 912 Free LCN 354 ACK -> 10-1051
1ffc5020d896243 Passport DCC:0 LCN 354 Unkey -> 10-1051
1c0450a8a88a1aa Passport DCC:0 450MHz N:1 S:10 I Nbr-> 450MHz N:1 452.01250
0f8057eae016266 Passport DCC:0 454.42500 Free 462.40000 Active(00) -> 10-64860
Thu May 13 18:48:35 2004 Dumper Version 10-Nov-2004
051457ef3016218 Passport DCC:0 454.42500 Free 454.06250 Active(00) -> 10-64998
Thu May 13 18:48:36 2004 Dumper Version 10-Nov-2004
0588503ddd960b6 Passport DCC:0 454.40000 Free 454.42500 Register -> 10-1979
0588503ddd947ad Passport DCC:0 454.08750 Free 454.42500 Register -> 10-1979
0588503ddd97084 Passport DCC:0 454.60000 Free 454.42500 Register -> 10-1979
0588503ddd95e1d Passport DCC:0 454.37500 Free 454.42500 Register -> 10-1979
Thu May 13 18:48:37 2004 Dumper Version 10-Nov-2004
0588503dddbb2c6 Passport DCC:0 461.82500 Free 454.42500 Register -> 10-1979
0588503ddd86831 Passport DCC:0 451.30000 Free 454.42500 Register -> 10-1979
0588503dd88c87f Passport DCC:0 452.50000 Free 454.42500 ACK -> 10-1979
0588503dd8b801c Passport DCC:0 461.20000 Free 454.42500 ACK -> 10-1979
Thu May 13 18:48:38 2004 Dumper Version 10-Nov-2004
0588503dd8be0b0 Passport DCC:0 462.40000 Free 454.42500 ACK -> 10-1979
0588503dd8bea04 Passport DCC:0 462.52500 Free 454.42500 ACK -> 10-1979
0588503dd8bc49d Passport DCC:0 462.05000 Free 454.42500 ACK -> 10-1979
0588503dd8c6051 Passport DCC:0 464.00000 Free 454.42500 ACK -> 10-1979
Thu May 13 18:48:39 2004 Dumper Version 10-Nov-2004
0588503dd896ee2 Passport DCC:0 454.57500 Free 454.42500 ACK -> 10-1979
057857eae03901f Passport DCC:0 461.40000 Free 454.37500 Active(00) -> 10-64860
0e0057e9b8160a5 Passport DCC:0 454.40000 Free 461.20000 Active(00) -> 10-64823
051c57eed014580 Passport DCC:0 454.06250 Free 454.08750 Active(00) -> 10-64986
Thu May 13 18:48:40 2004 Dumper Version 10-Nov-2004
0588d03dd89702d Passport *badpar (0057)
0e0057e9b815e0e Passport DCC:0 454.37500 Free 461.20000 Active(00) -> 10-64823
051c57eed03b2ce Passport DCC:0 461.82500 Free 454.08750 Active(00) -> 10-64986
0e0057e9b806826 Passport *badpar (0004)
Thu May 13 18:48:41 2004 Dumper Version 10-Nov-2004
1ffc503dd8962b9 Passport DCC:0 LCN 354 Unkey -> 10-1979
0e0057e9b816280 Passport DCC:0 454.42500 Free 461.20000 Active(00) -> 10-64823
Thu May 13 18:48:42 2004 Dumper Version 10-Nov-2004
Thu May 13 18:48:43 2004 Dumper Version 10-Nov-2004
1c0450a8a8bdee0 Passport DCC:0 450MHz N:1 S:10 I Nbr-> 450MHz N:1 462.37500
I think Im on my way now.....lots of Passport in KC
12-08-2004, 10:44 PM
Hello,
That is great. You need to set the time and date on your computer 8->.
Sometimes the serial port on a newer computer does not have enough drive to power a slicer. Mainly a problem with some laptops.
You are getting good decodes. Site number is 10. There are at least 2 other sites. See if you can receive the sites using 452.01250 and 462.37500. I did a quick search of the FCC DB and WPMU736 Commenco, Inc Kansas City MO located at 25th and Booth uses 452.0125. I could not seem to figure out the licensees for the other sites.
73 Eric
04-07-2005, 11:35 PM
ltr data slicer
Is there a commerical manufactured data slicer for sale that you can use on ltr multinet?
05-06-2005, 04:53 PM
I too would be interested in purchasing a filtered slicer. I also believe that the interest in this device will increase as more and more Passport and Multi-Net LTR systems go in around the country. In Dallas/Fort Worth, there are several new Passport LTR systems going in right now, thus my renued interest in this program.
Can someone please re-post a link to a picture for tap point "A" on the BC-780 for the filtered discriminator, or describe where I can find it on the board. Just tried the link in the LTRTrunk help file and it would not come up. I had one picture from some source, but it is obviously not a 780 board. Just opened mine up and its not the same. Thanks in advance.
73's
KD5ELF
