Go Back   The RadioReference.com Forums > Commercial and Professional Radio > LTR Trunking
LTR Trunking General discussion of LTR, LTR Multi-Net, and Passport Systems
Old 03-01-2007, 08:33 PM
Saint's Avatar
Default Ltr System @ tones
I listen to a LTR STANDARD System, and have noticed that when I do conventional frequency searches for new frequencies some of the frequencies in the LTR System have ctcss and dcs tones comming up with some of the LTR Frequencies. Is this normal that LTR frequencies also have ctcss and dcs tones for conventional modes.
Steve
BC396T Scanner
Pro-2045 Scanner Discriminator Tap
ARC396TPRO Software
Old 03-01-2007, 09:33 PM
Send a message via AIM to KCChiefs9690
They don't actually have tones, the scanner just thinks that they do. It could be some interference that the scanner is picking up and interpreting as tones, even though there are none in an LTR system.
Hope this helps,
Colin Taranovich
-GRE PSR-500 with Diamond RH77CA
-RS PRO-2055
Old 03-01-2007, 10:39 PM
A frequency is merely a frequency and perhaps is being used in a conventional mode and not in an LTR mode.
Old 03-01-2007, 10:43 PM
Saint's Avatar
Default re-tones
Hope this helps,
Thanks KCChiefs9690, it's the first time I came across this, I was just wondering.
Steve
BC396T Scanner
ARC396TPRO Software
Old 03-01-2007, 11:11 PM
dtscho's Avatar
It could be a situation where the same frequency is used as part of an LTR system, and is also used as a conventional channel with a CTCSS/DCS tone.
Dave
Old 03-15-2007, 07:15 PM
LTR systems do indeed have tones. Since there's no control channel, the control information is sent as data via CTCSS tones. I've not seen any DCS used, but likely someone is now doing it. There's a standard set of tones used for the control information. It was initially set at 150Hz. Initial communications handshakes take place as well as continuous exchange of data via this subaudible channel during conversations between the repeater and the mobile units to ensure that mobiles are accessing only authorized systems and to see what repeaters are available. Voila--no dedicated control channel! Uniden Commerical also has an enhanced LTR protocol called Extended Sub-Audible Signaling (ESAS) which allows radios to be uniquely identified and allows "roaming" between different LTR systems. When listening in on an LTR system using conventional mode vs LTR trunking mode, you may indeed notice the tones and wonder ... but again, it may also be an adjacent system, as mentioned above.
Old 03-15-2007, 09:35 PM
DaveNF2G's Avatar
Important note: CTCSS != subaudible datastream
David T. Stark, NF2G
Educator - Criminal Justice, Sociology
NF2G's Forensic Scannist Pages http://nf2g.com/scannist
Don't run from the police. Motorola always beats Mopar!
Old 03-16-2007, 10:45 AM
Yep. Datastream--modulated or unmodulated (regarding data content--obviously if a tone is present, it's "modulated" but not talking about that here). CTCSS is a continously transmitted subaudible tone, with no internally modulated data. DCS is continuously modulated subaudible data that uses a 134.3Hz tone as a bit timing rate. DCS sends a standard 23 bit asynchronous datastream, LTR sends several types of a longer, continuous, synchronous datastream using a subaudible tone base. They're all related and it sounds like a tone on the signal--which indeed it is--but it's used differently in different systems.
Old 03-16-2007, 10:58 AM
grem467's Avatar
keep in mind that some LTR controllers can also be set up to use PL/DPL at the same time, making the channel available for conventional use when a trunked user does not need it.
This is a good use for a single channel LTR system where the goal is to use it as a community repeater.
Similar Threads
Limited Logistic Services (Reynoldsburg) LTR System Repeaters Confirmed jkm Ohio Radio Discussion Forum 2 02-23-2007 11:53 PM
SF giants LTR System? b52hbuff California Radio Discussion Forum 2 01-06-2007 02:28 AM
need help with nassau county n.y trunked system SPARKY70 New York Radio Discussion Forum 8 12-05-2006 11:17 AM
Total Communications LTR in Pensacola, FL DanHenry Florida Radio Discussion Forum 0 11-19-2006 10:16 PM
Rochester & Olmsted County New Radio System GlacierClipper Minnesota Radio Discussion Forum 1 01-10-2006 06:44 PM
